Page 1 of 2
10cwt van rear brake shoes
Posted: Mon Jan 22, 2018 10:52 am
by paul
Does anyone know if the rear brake shoes on a 10cwt van matches up with any other vehicles? As i need two pairs of shoes for the rear of mine, and i'm finding it difficult to find any ! I know the 10cwt is different to all the other drum brake marinas, because size and width, and usually it's the front i find an issue to get, which match up with a Toledo, but this time round it's the rear that i can't find!
Re: 10cwt van rear brake shoes
Posted: Mon Jan 22, 2018 10:33 pm
They're listed on page 7 of the Earlpart catalogue
http://www.earlpart.co.uk/catalogue%20marina.pdf
Posted: Tue Jan 23, 2018 10:35 am
by paul
Hi there L.B.
Yes, i had seen those, but at £37.50 2016 prices, i will continue the search for more reasonably priced ones, until i'm desperate
Normally , i have been able to get two pairs of shoes, either front or rear, for my van for around £15. which, as i tend to use my van, and brakes, a lot (10,000 miles a year on average) . So i tend to go through the shoes!
Posted: Tue Jan 23, 2018 1:21 pm
If you find your local commercial brakes and hoses specialist. They will be able to get your original shoes relined with new material for you
Posted: Tue Jan 23, 2018 2:57 pm
I think I have some somewhere, let me check tonight.
Posted: Mon Jan 29, 2018 10:14 am
by trigger
I bought a set for my Ital 575, I presume the Marina and Ital are the same. My local motor factors kept them at £27 though I found out I could have got them of eBay for £18. I'll try and find the part number, they were the same as MGB ones from memory.
Posted: Mon Jan 29, 2018 2:03 pm
Paul, I can’t find the ones that I thought I had - sorry. Trigger is right Marina/Ital 10cwt/575 rear axle uses the same brake shoes as MGB
These are the cheapest on EBay - £10.
https://www.ebay.co.uk/itm/MGB-brake-sh ... 2930651457
Posted: Mon Jan 29, 2018 10:54 pm
That makes sense. Wasn't the axle derived from the early MGB/A60/Oxford banjo axle?
Posted: Mon Feb 05, 2018 12:05 pm
by paul
thank you all, that's helpful, will try MGB ones and see what happens
Posted: Tue Feb 06, 2018 10:02 am
by paul
Latest is that all those i approach, from the MGB angle, cannot confirm they are the same, as all listings i have found say just MGB. Do any of you have any confirmation that they are the same?
Posted: Tue Feb 06, 2018 12:57 pm
Yes the part numbers are the same.
Posted: Tue Feb 06, 2018 4:15 pm
by paul
Thanks Chris,?
is that part number the BL part number? or the brake shoe manufacturers number? Like GBS740? (which seems to be the most common MGB number)
cheers
Posted: Tue Feb 06, 2018 6:11 pm
Based on that Chis says they the same and the Unipart Part number GBS740 I have been on my Delphi Webcat gives cross reference of LS 1023
I have screen shotted picture and sizes so you can check if same as on your van.
Posted: Tue Feb 06, 2018 7:19 pm
Posted: Tue Feb 06, 2018 7:47 pm
I Have Re searched the Delphi webcat on GBS 610 Cross reference to LS1037
