Leyland Marina panel differences
dazza2623
Post by dazza2623 » Sun Jul 08, 2018 1:23 pm
Rear floor area & inner guard of Leyland Marina
Marina 6 one day,V8 the next
Re: Leyland Marina panel differences
Post by mickthefitter » Sun Jul 08, 2018 9:58 pm
I'm not sure why we are seeing this, but I'm impressed by the lack of ferrous oxide!
dazza2623
Post by dazza2623 » Sun Jul 08, 2018 11:29 pm
People ask about the differences between the Aussie cars to UK.
The rear shock bracket.
Large longitudinal gusset across top of inner guard.
dazza2623
Post by dazza2623 » Tue Jul 17, 2018 10:49 am
More views of inner guard area
Post by MarinaCoupe » Tue Jul 17, 2018 3:52 pm
Very interesting stuff, they must have been worried about the weight of the Red 6 engine, as this would brace the top of the inner wing, it would also cover the rust trap behind where the bonnet hinges are.
dazza2623
Post by dazza2623 » Wed Jul 18, 2018 11:26 am
I believe the weight of 6 is less than B engine. A little bit more over hang from towers.
I have noticed that when the panel van is lifted with a crane through the front tow eyes there is flex between front guard & front door.
It was not evident when the same thing was performed on my V8.
dazza2623
Post by dazza2623 » Wed Aug 08, 2018 8:23 am
Differential of 6 cylinder
Front LHS of engine altered to take bigger radiator.
Bracing from tower to firewall different.
Tunnel larger.
Post by locost_bryan » Sun Aug 12, 2018 5:32 am
Larger tunnel to take the Borg Warner 3-speed manual box. iirc steering rack raised 30mm as a result, with different steering arms on stronger redesigned uprights.
Post by Morris McKinnon » Sun Aug 12, 2018 9:59 am
Looks like everything was welded in by hand rather than spot welded. Interesting stuff :thumbup:
dazza2623
Post by dazza2623 » Wed Aug 15, 2018 12:21 am
There is some welding done on the standard car plus the usual spot welds. This car has had some more added for strength. I think the steering arms were Kimberley or Tasman.
