71 TC Coupe on Car and Classic
Re: 71 TC Coupe on Car and Classic
Post by ScreamingLordStokes » Fri Feb 02, 2018 4:53 pm
Thing is, if the car is to have a full respray into blaze wouldn't the vinyl roof have to come off anyway? I suppose it could be masked, but would that spoil the paint job?
Post by balmy » Fri Feb 02, 2018 5:44 pm
ScreamingLordStokes wrote:Thing is, if the car is to have a full respray into blaze wouldn't the vinyl roof have to come off anyway? I suppose it could be masked, but would that spoil the paint job?
Really easy to mask off. Has a natural line to work with.
Mine was done ok.
Post by david painter » Fri Feb 02, 2018 5:49 pm
If I was spraying it I would remove lower moulding on C pillar at base of vynil and mask to edge of roof and on the A post would carefully peel it back about 3/4 inch and mask the masking lines would not be seen once the moulding is re fitted at rear and the roof re glued at the A Post
Post by ScreamingLordStokes » Fri Feb 02, 2018 8:29 pm
Cool, just a matter of personal taste then.
Post by balmy » Fri Feb 02, 2018 9:34 pm
david painter wrote:If I was spraying it I would remove lower moulding on C pillar at base of vynil and mask to edge of roof and on the A post would carefully peel it back about 3/4 inch and mask the masking lines would not be seen once the moulding is re fitted at rear and the roof re glued at the A Post
Pretty certain they did that with mine on the c pillar anyway.
Post by ScreamingLordStokes » Fri Feb 02, 2018 10:37 pm
Looking again at the description of the car on the auction site, it says it had a new vinyl roof fitted in 2015. So I suppose it would be a shame to get rid of it.
Post by Morris McKinnon » Sat Feb 03, 2018 3:18 am
My white saloon TDT had a vinyl roof before my ownership but it didn't go down the A pillar, it stopped at the top window frame. Not sure if it was fitted from new but from the photos I have (taken around 2001) it looked professional.
Post by JubileeNut » Sat Feb 03, 2018 5:47 pm
They often stopped just below top of windscreen to save on vinyl material. Loads of vinyl was wasted on mine for rear and front screens plus the sunroof
Post by ScreamingLordStokes » Sat Feb 03, 2018 6:03 pm
As a matter of interest, how much did yours cost Paul? If you don't mind me asking? Or how much are they in general if you don't want to be specific?
Post by JubileeNut » Sat Feb 03, 2018 6:06 pm
From memory it was about £300 fitted and made.
Post by JubileeNut » Sat Feb 03, 2018 6:09 pm
As i said lots of wasted vinyl as the sunroof was trimmed to match but could not use the piece cut out for the hole as it would be to small so another piece was used. Sunroof was done by another person as it required a fair bit of skill.
Post by ScreamingLordStokes » Sat Feb 03, 2018 6:15 pm
Cool, i suppose having the sunroof would've added a fair bit to the cost as well compared to a plain steel roof?
Post by JubileeNut » Sat Feb 03, 2018 9:13 pm
The Britax Weathershield sunroof was fitted 2 years after the car was built. When BL fitted vinyl roofs often the metal underneath was only in primer sometimes. But re trimming the Jubilee roof did cost a bit but the vinyl had to come down the A pillars to look right.
