10cwt van rear brake shoes
Moderators: ClaytonSpeed, Number 63, balmy, norway_triumph
paul
Post by paul » Mon Jan 22, 2018 10:52 am
Does anyone know if the rear brake shoes on a 10cwt van matches up with any other vehicles? As i need two pairs of shoes for the rear of mine, and i'm finding it difficult to find any ! I know the 10cwt is different to all the other drum brake marinas, because size and width, and usually it's the front i find an issue to get, which match up with a Toledo, but this time round it's the rear that i can't find!
Re: 10cwt van rear brake shoes
Post by locost_bryan » Mon Jan 22, 2018 10:33 pm
They're listed on page 7 of the Earlpart catalogue http://www.earlpart.co.uk/catalogue%20marina.pdf
2008 Honda Jazz 1.3 CVT
Nothing gets the ladies hotter than software development analogies. Leonard Hofstadter - The Big Bang Theory.
paul
Post by paul » Tue Jan 23, 2018 10:35 am
Hi there L.B.
Yes, i had seen those, but at £37.50 2016 prices, i will continue the search for more reasonably priced ones, until i'm desperate ;)
Normally , i have been able to get two pairs of shoes, either front or rear, for my van for around £15. which, as i tend to use my van, and brakes, a lot (10,000 miles a year on average) . So i tend to go through the shoes!
Post by david painter » Tue Jan 23, 2018 1:21 pm
If you find your local commercial brakes and hoses specialist. They will be able to get your original shoes relined with new material for you
Post by MarinaCoupe » Tue Jan 23, 2018 2:57 pm
I think I have some somewhere, let me check tonight.
trigger
Post by trigger » Mon Jan 29, 2018 10:14 am
I bought a set for my Ital 575, I presume the Marina and Ital are the same. My local motor factors kept them at £27 though I found out I could have got them of eBay for £18. I'll try and find the part number, they were the same as MGB ones from memory.
Post by MarinaCoupe » Mon Jan 29, 2018 2:03 pm
Paul, I can’t find the ones that I thought I had - sorry. Trigger is right Marina/Ital 10cwt/575 rear axle uses the same brake shoes as MGB
These are the cheapest on EBay - £10.
https://www.ebay.co.uk/itm/MGB-brake-sh ... 2930651457
Post by locost_bryan » Mon Jan 29, 2018 10:54 pm
That makes sense. Wasn't the axle derived from the early MGB/A60/Oxford banjo axle?
paul
Post by paul » Mon Feb 05, 2018 12:05 pm
thank you all, that's helpful, will try MGB ones and see what happens 8-)
paul
Post by paul » Tue Feb 06, 2018 10:02 am
Latest is that all those i approach, from the MGB angle, cannot confirm they are the same, as all listings i have found say just MGB. Do any of you have any confirmation that they are the same?
Post by MarinaCoupe » Tue Feb 06, 2018 12:57 pm
Yes the part numbers are the same.
paul
Post by paul » Tue Feb 06, 2018 4:15 pm
Thanks Chris,?
is that part number the BL part number? or the brake shoe manufacturers number? Like GBS740? (which seems to be the most common MGB number)
cheers
Post by david painter » Tue Feb 06, 2018 6:11 pm
Based on that Chis says they the same and the Unipart Part number GBS740 I have been on my Delphi Webcat gives cross reference of LS 1023
I have screen shotted picture and sizes so you can check if same as on your van.
Post by MarinaCoupe » Tue Feb 06, 2018 7:19 pm
Oops should have said,
BL parts manual GBS 610
https://www.ebay.co.uk/itm/ROVER-TR5-2- ... 2479894254
Post by david painter » Tue Feb 06, 2018 7:47 pm
I Have Re searched the Delphi webcat on GBS 610 Cross reference to LS1037
