Post
by palacebear » Mon Jun 15, 2020 3:59 pm
After a month of inactivity (plain laziness to be honest), progress at last with the fuse box mystery. I'd been fiddling around under the bonnet doing unrelated stuff. Having completed my tasks I found the wipers, washers, indicators, reverse lamps etc., etc weren't working. I remembered the same situation had arisen last year after being rescued by the RAC and was caused by a multi-pin connector attached to the wiper motor being dislodged. Once again I'd dislodged it. I reconnected it and was rewarded with a little spark and brief movement from the wipers (I'd forgotten to turn the ignition and wiper switch off), then nothing again.
The fuses in the fuse box were all intact. The car has an auxiliary fuse box under the bonnet containing a 35 amp fuse which once protected a long-since removed Kenlowe fan. These days it protects the screenwash pump and its after-market relay. On this occasion, the fuse had blown. With a new fuse fitted, it was all business as usual, indicating that the reverse lights, brake lights, heated rear window circuits have been re-routed through this auxiliary fuse box, although exactly how the wiring has been changed remains, for the moment, a mystery. At least I know the circuits aren't, as I feared, un-fused.
