Hi all
Used a Maestro setup in he end which looks same as Metro pic David attached, had to modify the switch holder to fit at the end of the barrel but works perfectly when held in by the anchor screw on the barrel. Should have taken some photos for you to see sorry but it does work with a small bit of modifiction and was £35 on ebay with 2 keys just happy I'm back on the road
Thanks all for your help
Jeff
Stuck Key Ignition
Re: Stuck Key Ignition
Thats good you have fixed it at a reasonable price and with a part that is likely to be more available than the Marina one
