Wrong engine, right?
Re: Wrong engine, right?
Post by MarinaCoupe » Tue Aug 06, 2019 11:01 pm
The block will have the blanking plate fitted in the same location as the Marina fuel pump, you should see two bolt heads.
Post by locost_bryan » Tue Aug 06, 2019 11:19 pm
Xephe
Post by Xephe » Wed Aug 07, 2019 7:48 am
One of the pics from the online advert:
Pic of the side of my engine:
Looks to me like there’s no blanking plate or boss at all from that view. Curious.
Post by MarinaCoupe » Wed Aug 07, 2019 7:58 am
Very curious, I stand corrected, maybe it was only the 18Vxxxxxxx engines that had it.
Any who, looks like you’ll need an electric fuel pump. I used a NZ made FuelFlo 015 on my TC powered Coupe.
Xephe
Post by Xephe » Wed Aug 07, 2019 9:35 pm
I’ll keep an eye on the auction. Fuel pump can be sorted out easily with the fuelflo. I would still be a little worried that the block might be hiding some other surprise differences though that only become apparent when bolting on the ancillaries.
It would be interesting to find out more about the variance between the engines, why, when etc.
Post by david painter » Thu Aug 08, 2019 7:31 am
I have a old MGA block in the shed strangely it has the fuel pump mounting cast into it and the studs but has never been drilled to take a mechanical fuel pump
Xephe
Post by Xephe » Thu Aug 08, 2019 9:26 am
What year do you reckon your block is? I have done a bit of trawling and can find pictures of different MG blocks, some with no mounting, some with mounting but not drilled and some with blanking plate. I can’t nail down any specific information like a year it changed or anything like that.
The great fuel pump mounting mystery!
Post by david painter » Thu Aug 08, 2019 1:35 pm
I don't know exactly to be honest its been in the shed over 30 years I suspect mid to late 1950's
