Mgb exhaust
Mgb exhaust
Post by Kilroy » Fri Oct 16, 2020 9:47 am
Hey all.
During my current Estate rebuild a friend suggested that I should make it sound like an MGB.
Not a bad idea actually.
What I would like to know is how different is the Marina front downpipe setup as compared to mgb.?
Perhaps they are interchangeable.?
To my knowledge the mgb used a front muffler and a rear resonator.
Not sure if either or both of those were in any way special.
Having spent some time searching locally for mgb mufflers and failing, I am thinking that I need to involve mgb people.
Seems a bit of a comedown for a Marina owner....
Interested in anyone's insight.
Thanks.
Re: Mgb exhaust
Post by MarinaCoupe » Fri Oct 16, 2020 12:57 pm
The cast iron exhaust manifolds are essentially the same, the twin down-pipes on the Marina are slightly shorter than the MGB. The other variable could be the internal diameter of the main system could be different, which will produce a different resonance.
Re: Mgb exhaust
Post by david painter » Fri Oct 16, 2020 1:35 pm
On my MGB The main silencer is just forward of the rear axle U bend It is a straight though silencer unlike the Marina offset one is also slightly longer from memory with a similar diameter ( I can check actual dia if required) the rear resonator box is again similar diameter to Marina one it is also again longer with down turned tailpipe i think both would fit though
Re: Mgb exhaust
Post by Kilroy » Fri Oct 16, 2020 10:38 pm
Thank you both.
Looks like I am on a muffler hunt.
Re: Mgb exhaust
Post by ClaytonSpeed » Sat Oct 17, 2020 10:05 am
The UK TCs with mild steel pipes and their original 'torpedo' rear resonator always sounded far better than any MGB I've heard or driven.
Isn't the MGB is a shorter car? That might have an effect on what it will end up sounding like.
Re: Mgb exhaust
Post by locost_bryan » Mon Oct 19, 2020 1:43 am
My nieghbour's had a NZ new HL that sounded exactly like an MGB, wonder if NZMC specified MGB-style mufflers, since the exhaust system was made locally?
MGB forums say 1 5/8" ID (1 7/8" OD) tailpipe is standard, recommend 1 7/8" ID (2" OD) for a 100-120bhp engine.
http://www.superstreetonline.com/how-to ... w-exhaust/
Re: Mgb exhaust
Post by Kilroy » Mon Oct 19, 2020 7:39 am
Thanks for the info guys.
I have no idea what was originally fitted as all now seem to possess replacement items that often do not look as though they were designed to fit in the space provided.
Was the original front muffler on the Marina an offset type or were the pipes central both ends..?
Re: Mgb exhaust
Post by david painter » Mon Oct 19, 2020 7:43 am
Centre UK Silencer was offset with what looked like e perforated baffle inside
Re: Mgb exhaust
Post by Kilroy » Mon Oct 19, 2020 7:46 am
Thank you Dave.
Re: Mgb exhaust
Post by ClaytonSpeed » Mon Oct 19, 2020 7:51 am
The MGB factory mid exhaust box in this shot from Bryan's link looks very similar to the RC40 as used on minis:
Obviously with straight in/out pipes. Now, they do sound nice on B series engines.
Re: Mgb exhaust
Post by locost_bryan » Mon Oct 19, 2020 9:05 pm
Not really relevant for the B engine, but this Marina 6 rear muffler system is for sale on ebay Australia (for $400!). Appears to be just the single muffler.
Nos Repco Leyland Marina 2.6L Exhaust Rear Muffler System M2859
Re: Mgb exhaust
Post by Kilroy » Tue Oct 20, 2020 5:48 am
Maybe they would sell me 2/3 of it...
Re: Mgb exhaust
Post by MARINAMADBAZ » Tue Oct 20, 2020 10:05 pm
my gt has no rear silencer just a straight thru pipe after the Swan neck sounds great!
Re: Mgb exhaust
Post by Kilroy » Wed Oct 21, 2020 8:38 am
I was running the same setup on the yellow car prior to removing the engine for use in the estate.
While it sounded pretty business, there was a harsh quality to the sound that did not please me, hence my idea that the use of a resonator might smooth the sound out a bit without muffling too much.
This was the old exhaust, which does not fit on the estate as the rear valance arrangement is different...
https://www.youtube.com/watch?v=FSTvNg4571E
Loud mechanical noise from the engine bay was the water pump announcing its demise.
Now replaced.
