What colour for my Coupe?
Thanks guys
The gearbox is a Spitfire 1500 Overdrive, with a Marina 1800 input shaft. Same casing and ratios as 1.8 Marina, bolts straight up to the Marina bellhousing and uses standard Marina clutch, has the same output flange as the Marina propshaft which just needed shortening a tad.
The gearbox mount is a one off and as you can see I had to raise the line of the gearbox tunnel.
- minispeedstar
All,
It's gonner be Harvest Gold again! I trailered her down to Paul Mondey's on Saturday - so it's underway.
Appeal
Somehow I have lost the nearside headlamp panel that I bought a couple of years ago. Anyone got a spare? Paul's going to need it in about 10 days time. FOUND HEADLAMP PANEL!
Also - the handbrake lever gaiter has a split in it, anyone got a spare or a good use one?
Appeal
there were alsoEL Presidente IOW wrote:first list only the following had Navy trim as
standard.... 1, 2, 4, 5, 9, 11, 13, 14, 15, 17..(.some of these as an option)
Rheingold (metallic) don't know if it was offered in UK, but it was overseas with (autumn leaf (brown) interior
Personally i would have gone for the original colour even if it's quite "common"
- The General
- stuthegasman
- The General
