Hi Son,
Stainless steel has always been a very general term for some alloy steels, they used to be steel with chrome, molibdinum (can't spell), vanadium added. More or less of each alloy and now nodoubt others to produce the properties required. Some are easily machined while others require special cutting tools or grinding.
I've a lump here to make a clutch slave cylinder from, as its to be turned and only has low pressure I intend to make it very thin and so lighter than the cast iron jobby (just to see how dificult the job is).
Dad!
Clutch Push Rod - Dimensions
Re: Clutch Push Rod - Dimensions
Shopping trolley(Mazda3)
Details of stainless grade below
Does anyone want the spare push rod i have for free??snowy wrote:I have a spare that i will never need (Cable clutch) that i will post out free of charge to you. PM me your address.MarinaCoupe wrote:See above Steve,
Thanks for the dimensions, Martec beat you to it! Already bought some stainless steel rod to run some off.
If not i will throw it away....
I thought you were offering it to Chris to help make some more!
If not I will have it of you
snowy
If you want to send it to me I'll pass it onto the guy who is push-rodless. In the meantime I'll still have some stainless ones made up.
I'll PM you my address.
