Hi Stu, looks pretty good so far mate, to flat the runs out will take a lot of care and patience on your part, you will need a good quality hard rubber block , if they are really bad put a strip of masking tape either side of the run to protect the surrounding paint, then using your block, some 1000 wet/dry paper and some soapy water flat off the high spots of the run, then take off the tape and have a go with some 1200, once it looks level gently finish with 1500 till it`s smooth, be careful not to rub through around the area you are working, its very easy to slip up at this point. Once you have dealt with the runs, go over the whole lot with the 1500 and loads of soapy water, this will make all your shiny 2K dull, but don`t worry , when you buff it up it will shine again, but it should look better against your old paintwork, use a G mop which is a white sponge mop, or you could use a wool mop, BUT BE CAREFUL!, keep it moving and use a trigger bottle with some water with a little washing up liquid in it, to spray on some water to stop things getting too hot!. Be warned if you keep the mop in one spot for too long it will burn through the paint!, stay off the ridges and edges, you can finish those by hand, put a little G3 on a damp cloth & rub till it shines again. Finally give it a good wax to bring up the gloss ...jobs a good -un! As far as time goes before tackling all of this , with 2K you can usually do it next day, but i would leave it for a few days to go off nice and hard.
