I keep mine in our kitchen draw for safe keeping. It's not new but still has the wood effect :-)JubileeNut wrote:That should be wood effect plastic but most have had the surface wear away to leave a smooth orange yellow plastic!Yellow gear knob !!!![]()
I know as mine is new and still has all the wood grain!!
Marinas and the differences between them
Re: Marinas and the differences between them
V. Sad
Sent from my iPhone
Sent from my iPhone
The wood grain ones are the same as some Spitfire ones. Not that easy to find though, I wanted one for JWC!
- MARINAMAN480
Is this what you after PHUQ ?
Sent from my GT-I9100 using Tapatalk 2
Yes please
Out of interest, what is the arrangement around the rear windows (i.e. the side windows in the rear quarters) on yours? I assume the stainless was there from the factory. Not sure what I should do for mine there. The seals are very dead so open to options...
Cheeky I know, but would you be prepared to sell the ones from the front windows too?
- MARINAMAN480
Looks like this and they not factory fitted and yes can have fronts as well do you need the door pillar section 2
I don't know about the door pillar sections- saloon TC owners, what's the verdict?
I suspect the correct answer is "no", but it'd be nice to have them anyway
Let us know when you've had a think on a price. Racking my brains for any other non essential estate bits you might have on there too...
'Correct' answer is no but then again a TC estate isn't 'correct' so why not?
The more shiny bits the better
That was my train of thought too Josh. Bling, innit!
- MARINAMAN480
ObviouSly being an Ital won't have chrome trim for the piece where the quarter light is on front doors of mk 1
You could probably use stick on for that bit as it is straight and easy and would look OK
Providing I can find some the right profile that could work- that said, front doors are much less of a problem anyway, I'm sure I'll be able to find the proper missing bits from somewhere
