6 cylinder Marina upright,disc,hub
dazza2623
Post by dazza2623 » Wed May 08, 2013 12:15 pm
Some pics for you.
outer bearing Timken LM11949,Inner L44649 or 7 last digit distorted
Marina 6 one day,V8 the next
Re: 6 cylinder Marina upright,disc,hub
Post by ClaytonSpeed » Wed May 08, 2013 1:14 pm
Wow, quite a substantial difference in the bottom joint and where the caliper mounts. :surprised:
Post by locost_bryan » Thu May 09, 2013 12:36 am
beniboyz wrote:Wow, quite a substantial difference in the bottom joint and where the caliper mounts. :surprised:
UK leg (courtesy of Kilroy) vs Aussie leg.
Other Aussie differences are the "I-beam" has been turned 90 degrees, and the steering arm curves up (the rack was raised 30mm iirc).
Image Image
dazza2623
Post by dazza2623 » Thu May 09, 2013 9:49 am
Ben this is how yours will turn up.As you can see the hub & upright weighs in at 8kgs.Times this by 2 packaging @ 18-20 kgs.
Post by ClaytonSpeed » Thu May 09, 2013 10:24 am
Maybe i should rent a container on a freight boat at this rate!
dazza2623
Post by dazza2623 » Thu May 09, 2013 10:35 am
I took them to work & gave them a sandblast to get rid of grease & build up,that saved 3kgs. :-D
Post by MarinaCoupe » Thu May 09, 2013 11:10 am
Good solution Ben.
Will UK trunnions and top ball joints fit or will you be using Aussie ones?
Sent from my iPhone
Post by ClaytonSpeed » Thu May 09, 2013 11:13 am
Looks like the trunions are gonna have to be Aussie spec. Not sure about the ball joints.
dazza2623
Post by dazza2623 » Thu May 09, 2013 11:25 am
Ball joints are supposed to be the same.
Can you get new trunnion shaft & sleeve kits ?
These uprights were apparently used in the South African v8 rally car.
Post by ClaytonSpeed » Thu May 09, 2013 11:32 am
dazza2623 wrote:Ball joints are supposed to be the same.
We don't have sleeve kits over here. They do a larger trunion kit that has its own sleeve that would "repair" a UK leg. They wouldn't suit the Aussie one I wouldn't think. Unless it could be fitted without its sleeve.. Interesting thought..
dazza2623
Post by dazza2623 » Thu May 09, 2013 12:35 pm
Do you have any measurements on the kits so I can check.We can always live in hope.
Post by ClaytonSpeed » Thu May 09, 2013 12:53 pm
I will have a look to see if I have one to hand.
dazza2623
Post by dazza2623 » Fri May 10, 2013 10:54 am
Thanks,just interested.
