UPDATE! Half shaft and hub modification - other options.
Re: UPDATE! Half shaft and hub modification - other options.
Post by MarinaCoupe » Tue Jan 06, 2015 7:21 pm
What's the difference in cost David? You could be penny wise and pound poor with the wrong decision.
Post by david painter » Tue Jan 06, 2015 7:28 pm
Yes thats my feeling as the other shaft continues to drive so no sudden grip from light shaft hence no wind up of shaft as that is what causes most halfshaft breakage
Post by balmy » Tue Jan 06, 2015 8:02 pm
MarinaCoupe wrote:What's the difference in cost David? You could be penny wise and pound poor with the wrong decision.
Difference between £400 and a grand........
Post by balmy » Tue Jan 06, 2015 8:04 pm
david painter wrote:Yes thats my feeling as the other shaft continues to drive so no sudden grip from light shaft hence no wind up of shaft as that is what causes most halfshaft breakage
Makes sense. Was planning on adding an lsd anyway.
For the same money as the rakeway I could have the uprated shafts and the lsd.
Post by david painter » Tue Jan 06, 2015 8:08 pm
If it was me thats the way I would go shafts failing at wheel bearing end is unusual. May be Caterham issue when autotesting due to excess side loading.
Post by PHUQ » Tue Jan 06, 2015 8:50 pm
Uprated shafts + LSD sounds like an excellent plan to me :mr green:
MARINAMAN480
Post by MARINAMAN480 » Wed Jan 07, 2015 7:14 am
Anyone want todo factory tour of Quaife engineering? They make and fit LSD s and think they still list a marina in there catalogue for lsd
Post by PHUQ » Wed Jan 07, 2015 4:31 pm
They do Lee- pretty sure that is Mr Balme's intended source ;) Aimed at the Caterham crowd really I guess.
MARINAMAN480
Post by MARINAMAN480 » Wed Jan 07, 2015 8:25 pm
Cool i can pick stuff up from them as up the road from mother in law
