Early marina brakes
Keith Anderson
Early marina brakes
Hi all ,I have a January 1972 1.3 coupe that I am restoring and I need to know what type of front and rear wheel cylinders or repair kits I need there appears to be two types my chassis number is 46762 so am I right in thinking I need the early type?
Re: Early marina brakes
Josh will be along shortly, he's the early car man.
Hi Keith, good to see you on here. Yes you need the early type. The early front wheel cylinders are 19mm- same as Triumph Herald and Anglia 105E. They are available new. You need early shoes as well, usually available on eBay. Rear cylinders on early drum/drum cars are 17.5mm. Same as disc/drum cars from late 72 to 1980. Again these are available new.
Keith Anderson
Cheers Josh I realised that the front cylinders were the same as my anglia after I took them off,thanks for the info on the rears
On my early car the rear cylinders are dolomite sprint and shoes same as escort mk1. It's a TC so may differ
Early 1.8s and TCs had different sized wheel cylinders and were auto adjust.
As it says in the listing, those ones are for 1973-1975 models. Early ones had different shoes and cylinders
http://www.ebay.co.uk/itm/Front-Brake-S ... SwdGFYqFGk
Thanks- shows me how many different variations of components there were.
