They seem to be a helluva lot tougher than the 4 speed 'box. I'd do as you suggest, oil change and swap the filter out, stick it back in and see how it goes.MARINAMAN480 wrote: Sat Feb 24, 2018 7:21 am Yes my box has ATF and I believe reading on some forums that there is a special oil for them now its a cross between ep an atf so improves the gearchange.
For the amount the car will get driven once done mite just do an oil change and flush if I can and put up with the noise .
Sent from my MediaPad T1 8.0 Pro using Tapatalk
Mk3 Gold saloon
Re: Mk3 Gold saloon
- MARINAMAN480
Re: RE: Re: Mk3 Gold saloon
Didn't know they had a filter in them, something to look at when the weather warms up, but overtime pay coming in handyPHUQ wrote:They seem to be a helluva lot tougher than the 4 speed 'box. I'd do as you suggest, oil change and swap the filter out, stick it back in and see how it goes.MARINAMAN480 wrote: Sat Feb 24, 2018 7:21 am Yes my box has ATF and I believe reading on some forums that there is a special oil for them now its a cross between ep an atf so improves the gearchange.
Re: Mk3 Gold saloon
I thought the filter was a Land Rover addition, in the transfer box adaptor housing. Not fitted in SD1 & TR7 applications
Re: Mk3 Gold saloon
Ahh, you might be right there- mine certainly has one but now you mention it I think it's in the lump tacked on the back- sorry.
Re: Mk3 Gold saloon
Lee,
I found this some years ago on a Dutch SD1 website. LT77 gearbox rebuild in 5 parts (left side of the page) even I understood it.
http://www.roversd1.nl/sd1web/index.html
Re: Mk3 Gold saloon
Just had a quick look at the Dutch page, Very good looks like original factory training material, Nice find Chris.
- MARINAMAN480
Cheers Chris, still not sure about rebuilding the gearbox thats very handy for reference if I change my mindMarinaCoupe wrote:Lee,
Re: Mk3 Gold saloon
No probs, should answer questions about internal oil pumps and filters though.
- MARINAMAN480
Re: Mk3 Gold saloon
Just a quick update, i managed to get the engine bay painted yesterday.
- MARINAMAN480
Re: Mk3 Gold saloon
Its about time i updated this so here goes , get ready for a load of pictures
Sent from my SM-G981B using Tapatalk
- MARINAMAN480
Re: Mk3 Gold saloon
Some bits made their way back in to engine bay
- MARINAMAN480
Re: Mk3 Gold saloon
Front suspension has been stripped cleaned painted, new bushes, Torsion bars upgraded
- MARINAMAN480
Re: Mk3 Gold saloon
Removed rear axle, replaced pinon oil seal, new rear springs and poly bushes, new shock absorbers, and had a look inside my fuel tank.
- MARINAMAN480
Re: Mk3 Gold saloon
And now starting on the 2ltr Engine, looks like the main bearings and big ends are all ok.
