Yes, those too! The mk2s had a slightly different quarterlight to the mk1, not sure why though.mickthefitter wrote: Mon Jan 07, 2019 8:25 pmNoo noo noo.....also Mk2 Special and HL and GT. Then the Mk3 went and got rid of the whole triangular bit of glass thing.Morris McKinnon wrote: Mon Jan 07, 2019 7:42 pm Ah, of course. I forget, we never got quarterlights. Special order over here, wasn't it? ..except the Jubilee I think had them as standard.
Offerings from Down Under
Re: Offerings from Down Under
Oh...I don't have the benefit of experience. Mine has a little push button to unlock the latch before you turn it, were they omitted from the Mark 1?
No, they have like a filler piece in the corner.mickthefitter wrote: Mon Jan 07, 2019 10:48 pm Oh...I don't have the benefit of experience. Mine has a little push button to unlock the latch before you turn it, were they omitted from the Mark 1?
MK1 have a chrome thumb lever with a push button to release the lever. they cut the corner off the glass on MK2s to stop the wind Whistling through as the MK1s are bad for that. Jubilees were the first UK cars to have them as they has USA spec bits etc.
IVOR DENNEY
your right there PAUL some times when I have had mine open they can whistle especialy anything over 40MPH
It was only the Deluxe that had the vents deleted, and the two dial dash. The Super had the vents and a clock in the three dial dash. The Coupe only TC replaced the clock with a rev counter and added opening rear quarterlights.
Hadn't noticed the difference in the dash trim, will have to have a look later in my Bold as Brass TC Coupe.
Also note, the red saloon is a Series 2, badged as Leyland not Morris, and incorporating a raft of changes made for the Six. The front bumper is non standard, they didn't come with that extra bit in the middle, and it looks like it has an earlier Super grille. The eagle eyed might spot the fuel pump is driven off the cam, unlike the yellow coupe.
even with new seals they are a bit a poor fit, but mine may have got a bit twisted over the years!your right there PAUL some times when I have had mine open they can whistle especialy anything over 40MPH
Good to see you on the forum Ivor.
Hi
I acquired the red and white Marina. It is now in Brisbane. Goes well and is in great condition with zero rust.
It has a TC grill but only 1 carb. It’s a 3 speed auto and the only issue is that it rolls in park. Suspect it may be a linkage issue as highlighted elsewhere in this forum. Also wipers don’t return to park (also covered by this forum).
Happy to join the Marina Mob and have already got some great help. I also have a Coupe which is off the road but complete which Ingot for $700 oz dollars. Cheers BobbyV
BobbyV
Brisbane, Australia
'74 Leyland Marina 1750 Super Sedan
'83 Ford Capri 2.8i
'82 Mercedes 280ce
'84 Holden Statesman Deville
'69 Alfa Romeo Spider
'17 Tesla Model S 75D
Brisbane, Australia
'83 Ford Capri 2.8i
'82 Mercedes 280ce
Good news there, nothing that can’t be fixed there. We love pics Bobby, post away mate.
Hi, a couple of photos.MarinaCoupe wrote: Mon Jan 21, 2019 1:06 pm Good news there, nothing that can’t be fixed there. We love pics Bobby, post away mate.
Note TC grill (but single carb) and odd front bumper. Will send dash photos (does have a rev counter)
Cheers BoobyV
BobbyV
Brisbane, Australia
'83 Ford Capri 2.8i
'82 Mercedes 280ce
Brisbane, Australia
'83 Ford Capri 2.8i
'82 Mercedes 280ce
Hi Bobby,
Looks like you got a good deal.
I was given this info (from "BigCarl" iirc) for the Aussie "Leyland" Marina (after it was re-engineered for the E6 engine)
025 E2S4A17/8236
025 = Marina
E (odd, should be A for Manual or B for Auto)
4S = 4 Door Saloon (2S for Coupe)
2 = Super (1 for Deluxe)
A = 3 Speed Floor Shift Auto (L for 3 Speed Floor Shift Manual & M for 4 Speed Floor Shift Manual)
17 = E4 1.746 litre (14 for E4 1.485 litre & 26 for E6 2.623 litre)
8236 = serial chassis number
Based on that, your car should have the later vertical bar grille, and originally had a clock :-
The TC was only ever sold as a Coupe in Oz, and was dropped when the Six was released. The good news is the fours got all the chassis and brake upgrades from the six, so your car probably handles and stops better than the TC did.
025 E2S4A17/8236
025 = Marina
Is that black sill line (along the bottom of the doors) standard trim for this Australian model, or is it 'customised'? And do I see a solid black radiator expansion tank that you can't see the coolant level through?
The black paint was standard. Leyland Marina Red Six brochure.
I have seen black expansion tanks before, although mine is semi-transparent white.
Thanks Bryan,locost_bryan wrote: Mon Jan 21, 2019 11:04 pm Hi Bobby,
Looks like you got a good deal.![]()
025 E2S4A17/8236
025 = Marina
The TC was only ever sold as a Coupe in Oz, and was dropped when the Six was released. The good news is the fours got all the chassis and brake upgrades from the six, so your car probably handles and stops better than the TC did.![]()
that puts everything back into focus, much appreciated.
By the way, the Coupe I have (not running) is a '72 Morris Marina (before they changed to Leyland?) but I have no idea the engine size. Plate attached.
I should mention that my interest in Marinas stems from my father having one when I was growing up in Invercargill. He followed that with a Austin Allegro! I am still trying to find one of those.
Cheers BV
BobbyV
Brisbane, Australia
'83 Ford Capri 2.8i
'82 Mercedes 280ce
Brisbane, Australia
'83 Ford Capri 2.8i
'82 Mercedes 280ce
