Re: Hazards work, indicators don't?
Posted: Mon Nov 07, 2022 8:45 am
Hey, good to see you back, its been a whileKilroy wrote: Sun Nov 06, 2022 12:24 am My Mk3 Marinas have a complex switch that is responsible for allowing hazard lights to operate via two separate flasher units.
The sheer number of contacts within the switch mean that usually after operating it, weird symptoms are experienced when trying to use normal indicator functions.
Operating the hazard light switch a number of times will eventually restore normal transmission...
Is the hazard switch the same/similar as the MK4 Mini ones? I recall having similar issues and ended up stripping and cleaning the contacts in the switch to fix it once and for all, otherwise as you say, a lot of operating the switch would get it going for a bit.
