Page 2 of 2
Re: Sad times
Posted: Fri Jan 31, 2014 8:13 pm
I won't be fitting another box - I am too much in favour of maintaining the simplest (standard) setup as far as ease of repair and parts - especially as I have quite a collection.
I am a conservative driver as far as the way in which I use my machines. I do use the power - but I am gentle in the application.
I also use my brakes very little other than around town - just back off sooner, and go around corners fast.. :)
I believe this has much to do with the tremendous mileages I am obtaining from my cars.
That plus keeping the revs under 4500.
Use the torque Luke...
Oh - yes - that was original paint on the blue estate. Only ever saw one other - also an estate..
So now we are on chapter 2.. haha..
Cheers.
Re: Sad times
Posted: Fri Jan 31, 2014 9:37 pm
by Number 63
Loved that estate on superlites and the roadtrip stories that you did with it.
I'll raise a glass to it. 8-)
Re: Sad times
Posted: Sun Feb 02, 2014 8:32 pm
Kilroy wrote:I won't be fitting another box - I am too much in favour of maintaining the simplest (standard) setup as far as ease of repair and parts - especially as I have quite a collection.
A 2-litre with lots of bottom end torque - just go straight to fourth and let the torque do the work. :thumbup:
With the van diff ratio, you could just about start in top :eek: (like JC once did with a Jag on TG).
Re: Sad times
Posted: Wed Mar 12, 2014 11:01 pm
Kilroy wrote:This is it's 1905cc 11.5/1 B series and BW65 powerplant - 340,000K on and still going like hell.
Is that the milage for just the engine, or for the estate?
Re: Sad times
Posted: Sun Mar 16, 2014 12:14 am
The estate has covered 340,000K - I bought it around 1994 with a sickly E series engine in situ and around 160,000K on the clock.
The engine came from a 1976 HL which I swapped for a used washing machine a year or so earlier.
From memory it had covered about 170,000K and was completely original but rusty.
The engine was running fine - had driven it up to Nelson for a holiday - but as I wanted the estate to go something like how it looked, I rebuilt the engine using used Zephyr pistons and a different camshaft.
That got us to about 335,000K when I decided I wanted the original camshaft back in - so I took the opportunity to throw a new set of bearing shells in and give it a valve grind. No other parts replaced. Did not disturb the pistons.
Unfortunately, I only got one more wof out of it before the rust became an issue, and it was taken off the road.
Now we are using the motor/transmission in the sandglow saloon - should be good for another 100,000K I reckon...
Carjam does not seem to handle the speedo going over 100,000 very well..
Re: Sad times
Posted: Sun Mar 16, 2014 11:14 pm
by charlie safari
Sad News indeed I loved the look of that estate, I've almost given up on finding one up here!
I went to see one yesterday, yours was mint by comparison!
I do indeed have some Rover Box's in the shed if you need one ;)
Hows things Kilroy?
I've been snowed under with work lately so I havent been around a lot!
Bryans got my number if you ever need anything.
Re: Sad times
Posted: Mon Mar 17, 2014 10:07 am
Cheers mate.
Contact noted.. :)
