Post by Kilroy » Mon Sep 10, 2012 6:50 am
Yes - very good pump indeed. You would hardly think it possible.
I shall indeed be trying a bit of air pressure - but it needed to come out to do it anyway - and the car is rego'd - so I didn't want to waste any time.. ;)
If I use ENOUGH air pressure I might get a 10 gallon tank.!
Post by JubileeNut » Sat Sep 15, 2012 8:53 pm
Cleaned off some of the dirt from the wet journey to the IOW - went out on a nice drive all afternoon and then put car to bed :thumbup:
Post by ado28 » Sun Sep 16, 2012 12:58 pm
Lovin your cars pyjamas Paul lol :thumbup:
Post by JubileeNut » Sun Sep 16, 2012 8:09 pm
Cheers :thumbup:
They fit very well to when I can be bothered to line up the white stripe and I never put the nearside mirror in the mirror pod as it gets hard to remove then but keeps the dust of it :-D
1972TCCOUPE
Post by 1972TCCOUPE » Sun Sep 16, 2012 9:50 pm
Paul,I spy with my little eye,a tin of roses,a tin of cadbury celebrations and a 25 kg bag of mastercrete,anything else anybody can see?
The reason for my post,where did you get the cover? it fits so well.
Post by JubileeNut » Sun Sep 16, 2012 10:21 pm
I can assure you the tins are empty (Not all of them eaten by me :-D )
I am hoping the concrete is still OK as I have to fix a small wall my son has demolished :problem: :think:
There is a lot in the garage including 2 step ladders and the ladder hanging over the car is a 2 section 4M youngmans (Ladder porn - possibly). This is held up very securely :thumbup:
About 3 or 4 gear boxes and a back axle and prop.
Lots of measuring to make sure I could drive the car in without any dents :thumbup:
The cover was made for me by Classic Additions
Was not cheap but does fit nice.
Wanted a large Logo but that was just to much so I may add something later :D
Post by JubileeNut » Sun Sep 16, 2012 10:22 pm
Oil on the floor as well :rolls:
Just a drip or five
Post by ClaytonSpeed » Sun Sep 16, 2012 10:26 pm
Found a marina TC in a garage and moved it to my new unit:
Moved V8 too:
www.fastmarinamagazine.com
'71 Marina Coupe 3.9 EFI V8
4 Speed ZF Auto Transmission
SD1 4 Pots with Audi discs
Heavy Duty Suspension Pack
Telescopic Dampers
Post by JubileeNut » Sun Sep 16, 2012 10:29 pm
You need more stuff to make it like home Ben, looks lost in there.
you need more projects.
I can't swing a cat 180 degree's without knocking its block off in my garage :razz:
Post by ClaytonSpeed » Sun Sep 16, 2012 10:35 pm
JubileeNut wrote:You need more stuff to make it like home Ben, looks lost in there.
I really don't need any new projects! I like the rooooooom! I may have to build a false floor to store my goodies :-)
Telescopic Dampers
Kiwi Ute
Post by Kiwi Ute » Tue Sep 18, 2012 9:54 am
Kilroy wrote:Yes - very good pump indeed. You would hardly think it possible.
Well a pump sucked it in - another pump could just as easily pop it back out again! (Just don't stand near it when doing so, drape a few wet sacks over it while doing this)
Post by locost_bryan » Tue Sep 18, 2012 11:55 pm
If you fitted a reversible pump to the tank of an Aussie Marina, could you make it play a Stairway to Heaven like Rolf Harris's wobble board? :lol: :oops:
Post by ado28 » Sat Oct 13, 2012 2:35 pm
Last night I converted Reynards headlights to Halogens however one of the adjusters on NS bowl rotted out when setting it up on the beam setter so a quick bodge was required at work to get the light shining in the right direction. Second hand bowl dug out so I will pop back to work later and fit the new bowl! What a difference with Halogens lol
Post by MarinaCoupe » Sat Oct 13, 2012 2:37 pm
I agree about the halogens, it the difference between day and night isn't it? (pun intended)
Post by ado28 » Sat Oct 13, 2012 3:11 pm
Indeed Chris lol. I converted the mini last year and as I'm using Reynard as a daily it would have been rude not to convert that too. I just bought mini halogens and they are curved too so they still look the part. £25 delivered so I can complain and that included the bulbs too!
