Page 117 of 200
Posted: Fri May 13, 2016 9:05 pm
Got a new MOT today :thumbup:
Picture of grommet -
Posted: Fri May 13, 2016 9:20 pm
by marina12
Thanks. Always something new to learn about the cars!
Posted: Sat May 14, 2016 1:03 pm
by 1972TCCOUPE
Paul,do you know if these grommets are still available. They might be worth a try to keep things better sealed and avoid this stickng problem.
Posted: Sat May 14, 2016 8:08 pm
I got this off Ebay USA and he only had 2 of them. I have never seen another one for sale :frown:
I found the part number in a parts book and did a search on line so you could find one about.
Cheers,
Posted: Sun May 15, 2016 9:46 am
by italsi
Thanks for sharing tips on the clutch. The only 2 things not tried are the drop on jack method and gearbox out. Given its not been driven since 2001 I suppose it's expected to be more stubborn than most! As I've gained a second wind on the car and the welding is finished. I'm going to finish everything else off. Service/new rear dampers and sort some of the paint out. Basically so that clutch and mot are the last things. I'll let you know how I get on.
Posted: Sun May 15, 2016 12:16 pm
by 1972TCCOUPE
Found this parts diagram 22g1943, gaiter,clutch operating lever for heavy duty gearbox.
Posted: Sun May 15, 2016 12:36 pm
by marina12
Thanks. From there found this
http://thexpart.co.uk/Distributor-22G19 ... 6browse%3D
http://www.thexpart.com/XPART-MG-ROVER- ... +B+V+.aspx
Also a bit of discussion on the Marlin Owners Club forum regarding whether Lotus Ford equivalent might fit.
Here's one on eBay
http://www.ebay.co.uk/itm/Escort-Lotus- ... 2a6648a3ff
Posted: Sun May 15, 2016 2:36 pm
by jiversteve
marina12 wrote:Thanks. From there found this
Here's one on eBay
That was four years ago.
Different size entirely.
There was no demand, and the potential supplier I had, dried up shortly afterwards.
They had quite a stock of Marina parts and really wanted someone to buy the lot. Way beyond my means at the time, and I had plans to move to Spain so nowhere to store them all anyway.
Posted: Sun May 15, 2016 8:54 pm
I've bought stuff off the Netherlands chap. Bloody quick service!
Posted: Sun May 15, 2016 9:18 pm
by 1972TCCOUPE
For what I can make out they have nine in stock,I have emailed for a price,will post when I get an answer.
Posted: Sun May 15, 2016 9:26 pm
I have bought of this place as well, think it was light lenses.
Well found, I am sure there will be more out there somewhere.
Wonder what a heavy duty gearbox has that is different from standard?
Posted: Sun May 15, 2016 9:27 pm
I know they increased the main shaft size as I have both here and also reverse gear, laygear etc altered with chunky teeth.
Posted: Sun May 15, 2016 10:59 pm
The cage bearing in the back of the input shaft that takes the main shaft, is more robust. It then got used as the standard in later Mk1s.
Posted: Sun May 15, 2016 11:00 pm
You're not the only one that has emailed.
If you get the response first I'll have one off you.
Posted: Sun May 15, 2016 11:09 pm
MarinaCoupe wrote:The cage bearing in the back of the input shaft that takes the main shaft, is more robust. It then got used as the standard in later Mk1s.
My TC had the smaller bearing but I had it rebuilt and 'uprated' with the bigger bearing. Guess it was after '74 they came through as standard?
