Page 147 of 200
Posted: Thu Mar 22, 2018 1:42 pm
He has done a nice job of that for you
Posted: Thu Mar 22, 2018 11:24 pm
by Gee tc
Very pleased. Can now claim it to be quite rust free.
It was just a weak spot that didn't really show itself when first done. Couple of rainy show trips an the wet got under a pinhole that'd been missed.
Posted: Sat Apr 28, 2018 6:36 pm
by lock1506
Used it for its intended purpose, carrying my autojumble stuff around and towing a trailer full of panels. Had some strange comments from people saying "You should be showing that not using it like that" Its a van and I use it for what it was built for!!!
Posted: Mon Apr 30, 2018 6:43 pm
by Morris McKinnon
What I did to my Marina today was replace the shocks. PTH has been getting a little more bouncy over the speed humps lately so took advantage of the good weather today and changed them. While I was under there I replaced both the top swivel joints as one had some play in it.
On the drivers side I saw one of the wheel cylinders was leaking badly and on removing the lower shoe I took the lining with it! :lol: It was soaked in brake fluid so I wasn't really surprised.
The lower trunnions were still good so I left them.
Does anyone know if the lever arms can be serviced? They are pretty bad cos I can move the arms with very little resistance.
Posted: Mon Apr 30, 2018 7:21 pm
There are two things with lever arms, the bump and rebound resistance and the bushes keeping everything in line.
You can check the bushes for movement. There used to be companies that would replace the bushes, but I haven’t heard of anyone doing it for about 10 years, does anyone know who might rebush them?
The bodies can leak, but rarely. The internal valving shouldn’t degrade, so the only other element is the shock oil, which is available as it is the same as motorbike fork oil. There are various grades, there is another topic on here somewhere that details the appropriate grade.
Posted: Mon Apr 30, 2018 7:35 pm
by Gee tc
MarinaCoupe wrote:There are two things with lever arms, the bump and rebound resistance and the bushes keeping everything in line.
I had mine leak through the seals but there wasn't any play.
Posted: Mon Apr 30, 2018 7:52 pm
by Morris McKinnon
Yes, I did come across a thread on here somewhere on how to refill them but can't find it now. Mine were leaking quite badly so not sure if just refilling them would work. I think it was coming from where the arm pivots, but is hard to tell as you can see in the pic, they are soaking wet.
Yes, sorry, the play I was referring to was in the top swivel joint of the upright leg, the swivel pin and the cup it sat in had worn. When I cleaned them up it looked burnt so they've been dry for some time.
Posted: Thu May 03, 2018 12:34 am
by JoshWard
If it's possible to get them refurbished it would be worth doing as the early 1971 type ones are getting harder to find now.
Posted: Thu May 03, 2018 12:48 am
by Morris McKinnon
There was a guy down the road from me who used to refurbish stuff like this, not sure about Marina shocks though, he used to refill Hydragas suspension and such but I'm going back over ten years ago now and the guy was getting on a bit then so I doubt I'll have any luck there. What about Morris Minors? I know they are different but for such a popular car there should be someone refurbishing lever arms?
Posted: Mon May 07, 2018 6:47 pm
by Morris McKinnon
Working on PTHs sills today. They came up as an advisory on the MOT so instead of them failing next year and possibly involve replacing them it's best I look at them now rather than later!
I'll give the welds a skim of filler and paint later.
Posted: Mon May 07, 2018 8:09 pm
by Gee tc
Morris McKinnon wrote:Working on PTHs sills today. They came up as an advisory on the MOT so instead of them failing next year and possibly involve replacing them it's best I look at them now rather than later!
Fitted a new FM radio, aerial and improved speakers . Much better now. Hope Josh approves. Image
Posted: Mon May 07, 2018 8:25 pm
by Morris McKinnon
That's nice. Did Josh convert it to mp3?
Posted: Mon May 07, 2018 8:28 pm
by Gee tc
Morris McKinnon wrote:That's nice. Did Josh convert it to mp3?
Not on this.. I'll be using a transmitter.
I still have the first one from it that was done a while ago.. still working superbly but only mw/LW.
Posted: Mon May 07, 2018 8:36 pm
by Morris McKinnon
Those transmitters are pretty good, I have the type you plug into the cigi lighter. Got to have FM, though I think you get more stations on MW in England than in Wales so FM is a must for me. I can pick up three or four stations at the most here, maybe two at night.
Posted: Mon May 07, 2018 8:57 pm
by mickthefitter
There isn't much on MW in the East Midlands. Classic Gold is about all. Very period, but limited choice. I think you can get Radio 4, the odd sports channel, and at night the continental jabber but not really a wide selection.
