Mandator
Post by Mandator » Mon Jun 13, 2022 1:16 pm
Sent from my SM-J330FN using Tapatalk
Mandator
Post by Mandator » Tue Jun 14, 2022 9:26 pm
ScreamingLordStokes wrote: Mon Jun 06, 2022 7:31 pm Nice garage there! Good to get Kermit under cover (although I thought it might prefer being damp!)
Dunno what happened to my last post- supposed to be a reply to quote from Screaming Lord Stokes regarding damp!!! :-?
Here's hoping got it right this time. :)
Post by david painter » Wed Jul 06, 2022 1:32 pm
Gave the Brown Coupe a Quick clean down last night with Showroom Shine, charged up the battery to get it ready to take to a local show this evening if the weather holds out be the first time I have used it since the West Mid at the end of May
Post by ScreamingLordStokes » Wed Jul 06, 2022 4:39 pm
Great stuff, hope the weather does hold out for you David.
Mandator
Post by Mandator » Fri Aug 12, 2022 9:14 pm
Booked Kermit into the workshop to have the Trunnions and top joints done.
Mechanic has indicated the new ones (Walfords) are wrong??? but stated nothing wrong with old ones so he has greased them up and tickled em!
In doing so may have found the source of the knock I was hearing.
Prop shaft support bearing collapsed so this needs replacing - sigh!!
Are they still available from anyone?
Post by marina12 » Fri Aug 12, 2022 9:59 pm
No affiliation sure they are available more than just here
https://www.ebay.co.uk/sch/i.html?_from ... =10&_oac=1
Post by balmy » Fri Aug 12, 2022 10:53 pm
marina12 wrote:No affiliation sure they are available more than just here
He’s local to me. Always stupidly expensive!
Rinmers have them for £82.
https://rimmerbros.com/Item--i-GRID008478
Mandator
Post by Mandator » Sun Aug 14, 2022 12:31 am
balmy wrote: Fri Aug 12, 2022 10:53 pm
Ah Brilliant! Thanks Balmy.
Did see the E-bay listing but balked at the cost.
Thanks muchly for the heads up re: Rimmers. will give them a go.
Regards.
Post by ScreamingLordStokes » Mon Aug 15, 2022 3:42 pm
£82!!! Crikey, not so long ago they were £48! That's inflation for you!
Post by ClaytonSpeed » Tue Aug 16, 2022 7:20 pm
I've fitted Transit centre bearings to my cars. £15 posted but you have to re-use the Marina centre bearing ring.
Mandator
Post by Mandator » Sun Aug 21, 2022 6:51 pm
ClaytonSpeed wrote: Tue Aug 16, 2022 7:20 pm I've fitted Transit centre bearings to my cars. £15 posted but you have to re-use the Marina centre bearing ring.
Hah! Now you tell me - after I have bought one from Rimmers. :-D
Not sure the bearing ring is in a fit state. The whole donut (or Doughnut) is pretty shot!
Post by ClaytonSpeed » Mon Aug 22, 2022 3:01 pm
Sorry!
If you wanted one made up as a spare (I've a spare ring or two) let me know.
Mandator
Post by Mandator » Sat Oct 01, 2022 7:37 pm
ClaytonSpeed wrote: Mon Aug 22, 2022 3:01 pm Sorry!
Thanx for that. Sorry for slow reply been away from site a while!
Mandator
Post by Mandator » Sat Oct 01, 2022 7:43 pm
Have had the Rimmer Donut fitted to Kermit and now runs fine. Twas going to fit it myself but didn't have the inclination. Glad I didn't. Garage had problems separating the spline on the Prop. Jokingly said they had to pull it apart between two Fork Lift Trucks :)
Took Kermit up to the East Anglian Transport Museum last Saturday for the "Trolleybus Twilight Day" - Very enjoyable and Kermit ran a treat!
KwS
Post by KwS » Mon Oct 03, 2022 9:33 am
Started it for the first time since Feb, so I could drive it up the drive and spin it around. Now I can finally work on finishing the rust work and then start the fun stuff; reassembly and then putting it on the road again.
Oh yeah, the other reason progress slowed down, my SD1.
https://tasteslikepetrol.net/
