Page 3 of 3
Posted: Sun Oct 26, 2008 7:57 pm
Hi All - Update
Richard passed over the pukka BL rubber surround today and I will take it down to the re-manufacturer during the week, they are about 30 miles away and it gives me an excuse to give the Coupe another run.
I will ask for a written quote based on 25 units and publish here.
Re: COUPE REAR SCREEN RUBBERS!!!!
Posted: Sat Dec 27, 2008 10:26 pm
by JBA1
Hia
Any update on the rear coupe screen rubbers as yet?
Posted: Mon Dec 29, 2008 12:50 am
by Number 63
When it's sorted, I'm in for at least one. Will check with my brother but maybe two... :wink:
Posted: Mon Dec 29, 2008 5:19 pm
This has gone onto the backburner over the last copule of months, since Richard Clayton had his accident. I went to the molding co in October and to do a set of new rubbers will cost somewhere between £1500 and £2000 including 35 odd rubbers. If we have them done properly with moulded bottom corners (as per BL) it means the manufacturer making an extrusion for the channel and then separate moldings for the corners and then the whole things is bonded together (£2K). The alternative is that we have the channel molding made and then the bottom corners are mortised like a picture frame and bonded (£1.5K)
Also to make up the various moldings/extrusion sections they would have to cut sections in the complete one that Jan-Ivar supplied.
We hadn't got any further yet.
Posted: Mon Dec 29, 2008 7:07 pm
by minispeedstar
Don't like to be the one that said I told you so, but "I told you so!..." :roll:
Posted: Tue Dec 30, 2008 7:02 am
by norway_triumph
Coun't me in for a couple of the correct ones. I think that we "oldies" will have to get used to higher prices on parts for marina as the supply of new parts gradually gets used. When remanufacturing parts - prices should not be compared to what you saw it last time for 4-5 years ago , but with what similar parts for modern cars cost. I've seen this happen to spitfires/cortinas and no doubt it have happened to many other makes as well. I think it's been more than 10 years since i was offered a marina for free here in norway. Happy days
Posted: Tue Dec 30, 2008 10:32 am
Pilikington have written to me saying their prices are going up! I got my windscreen made by them (Formally Triplex) for £114 which I thought was a bargin. To original Sumdym spec with a top tint! Still more than some ex-stock suppliers but they were running out anyway so would need to put an order in which probably would be a similar or more on cost.
But as the Pilkington factory uses huge amount of electricity to heat treat the screens they have been hit bad by energy prices :roll:
So this has probably gone up a fair bit.
As companies go under remanufactured parts also get hard and more expensive and this is all at a time when poeple are loosing their jobs so can't afford the prices.
Just hope my job hangs in there as now on 4 day week :roll:
TC is is staying regardless of job though :D
