I washed the car today and for good measure hoovered it ready for the MOT this coming week.
- vermillion
What no polish Brian
Gary.
Gary.
Fitted good s/h rear brake drums obtained from Maestego via Ebay. The old drums had cracks between the wheel stud holes (presumably caused by someone overtighening the studs?) and also had bits broken off around the edges (caused by someone trying to remove the drums by smashing them with a hammer!!).
Would you believe Gary that the bonnet and roof I polished last November is still shiny and smooth..........the rest is cack.
PS serious consideration given to buying the wax polish!!!!!!!!
Went to start Reynard but his battery was flat
Went for a nice afternoon Drive on Sunday,
Sent from my Bat Phone
74 Tundra Coupe
74 TC " jubilee "
74 Tundra Coupe
74 TC " jubilee "
I know those refreshment rooms!!
Haha, and you will again in July!beniboyz wrote:I know those refreshment rooms!!
74 Tundra Coupe
74 TC " jubilee "
Took my saloon for its MOT test: passed ok (with a couple of advisories).
- charlie safari
Mine too!!! Fresh wof today, wiperblades and handbrake adjustScreamingLordStokes wrote:Took my saloon for its MOT test: passed ok (with a couple of advisories).
Started remodelling the front of the V8
aqua-marina
Looked at rear brakes checked cylinders weren't seized adjusted all up and bled,good job done so treated it to a good hoover then give a good run
- stuthegasman
removed my leaking radiator and knackered exhaust (what a job that was) and flushed the rest of the cooling system, power washed the engine bay and whilst the car was up on the ramps had a good look underneath and it's safe to say I don't need to touch the welder with this one, a few bits of paintwork to touch up here and there get the new exhaust and radiator back on and away we go...
Last weekend I gave my wife her 1st driving lesson in my Marina. She did very well!
74 Tundra Coupe
74 TC " jubilee "
74 Tundra Coupe
74 TC " jubilee "
I finally got round to swapping the dizzy clamp for the one off the TC lump, the one on there was a cheap looking one that came with the electronic converted dizzy and I'm hoping that's what was letting the timing keep slipping, and the fairly regular failures to start. If that doesn't work I'll swap the whole dizzy and we'll go back to points for a bit. Did go for a jaunt to the scrapyard in the sunshine yesterday though
