Page 4 of 5
Posted: Sun Nov 02, 2008 5:07 pm
by vermillion
Nice guess Chris. Spot on. A big big thank you to Andrew.
Posted: Sun Nov 02, 2008 5:09 pm
by andrewwita
yeah well done chris - i sent you a pm gary -
Posted: Tue Nov 04, 2008 10:26 pm
by Uncle Frank
How`s it going then Gary?...have you collected it yet/, what`s it like?, looks like you will have your work cut out mate, i`m not looking for work at the moment so don`t think i`m dropping hints!
, but be careful who you get to restore it, they are very tricky to get right, and if you do it yourself and you want any advice then feel free to give me a call and i will try and help as best i can
, well done, Linda Lusardi`s Mumford lives!
Posted: Tue Nov 04, 2008 10:49 pm
by vermillion
Thanks for the offer of the advice Frank. Haven't picked it up yet, hopefully on Sunday. I am going to do the restoration myself so any help I get will be welcomed. I know that it won't be easy but I have a plan of action whether it is right or wrong remains to be seen. If things go according to plan I hope to have it out for the summer of 2010. Gary.
Posted: Tue Nov 04, 2008 10:57 pm
by Uncle Frank
I will send you a pm with my number, each one i restored i learned something with the Mumfords, they can be improved a lot too, on both mine and Garys (minispeedstars) Mumfords i fitted 2"x1" steel box section inside the sills out of sight, this makes them much more rigid and reduces `scuttle shake`, if you contact Gary i`m sure he will send you some pics of the rebuild i did on his and you can see what i mean, the main worry with them is securing the door gap while the sills are cut off, you can get proper door bars from Sealey or just weld some steel bars across the aperture before you do any cutting
Posted: Tue Nov 04, 2008 11:10 pm
by vermillion
Have been running ideas around for a while now and had considered using 2"x1" box but was wondering where to secure it. The last one I did was a mini which had been bodged by a previous owner but I built a frame for that which ran up the A panels at the front and crossed under the dash and across the floor at the rear. It certainly strengthened it up. Glad that you have just confirmed that 2"x1" box can be used on the Marina as well. Thanks for the contact numbers I have a feeling they will be extremely valuable. Gary
Posted: Tue Nov 04, 2008 11:25 pm
by Uncle Frank
Just realised there are a couple of pics of Garys mumford sills on my `workshop thread` look under Mumford sills, they just fit in there nicely out of sight, leaving the car looking as original with only the Mumford 2"x1" bars showing inside the car!, i welded them each end and then to each`peak` on the inner sills, then sealed them top and bottom with `PU` sealer, worked a treat!
Posted: Tue Nov 04, 2008 11:27 pm
by vermillion
Thanks Frank will have a quick look then off to bed. Another long slog at work tomorrow. Gary.
Posted: Tue Nov 04, 2008 11:33 pm
by Uncle Frank
8) Me too, night night!
Posted: Sun Nov 09, 2008 10:19 am
by andrewwita
Posted: Sun Nov 09, 2008 10:30 am
by Chicken Hawk
It looks in preaty good nick,have you had a chance to check out how solid it is? Think you'r brave moving it with a specklift,got it back ok? Great to see anuther white "N" reg t.c! Going to look ace when its finished 8)
Posted: Sun Nov 09, 2008 2:34 pm
by JoshWard
Best of luck with it!!
Posted: Sun Nov 09, 2008 3:06 pm
by minispeedstar
Good luck! looks like your gonna need it
Those doors look worrying low when its lifted... :?
Posted: Sun Nov 09, 2008 5:23 pm
by JIM73
Best of luck Gary ! Try and keep us updated if you can !
Posted: Sun Nov 09, 2008 5:29 pm
by ice man
Have you got enough T cut to sort it out???
Good luck, it will be worth it.
