Bugger This.. I'm Going FORD!
- The General
- The General
- The General
well done m8 cant see what the problem is any marina on the road is a good marina only thing is the phrase Fix Or Repair Daily springs to mind
personaly i dont like fords but thats because i drive a cmax at the mo and their pooooooooo to say the least do you still need that pipe or have you engineered around it and can you confirm what you wanted me to make as in wheel nuts and how may sets i have remembered the pipes for the heaters your getting quite a nice box down here
Trev I still need some custom pipe work for the radiator. I need a pipe that curves around the N/S inner wing from the suspension turret straight to the front. I will do you a sketch with dimensions and PM you. I've got to make an air box adapter at the moment and need some 90 degree bends around the 45mm diameter.. Can you help with that?
- minispeedstar
Adz's one has got antiroll bars though Jim...JIM73 wrote:Well i for one am looking forward to putting this baby together and having a blat along the military road !!Im not sure Adz is gonna be happy bout this Ben !!
You know he's gonna want to race you !!
Yeah but mine is lighter and I have a roll bar to fit! =) Oh and Michelins not Good Years!minispeedstar wrote:
marinabrian
Modifications
15" x 8" Minilites, you are brave, better get yourself kitted out with a nice "classic" '70's Bullworker! , you're certainly going to need arms like Popeye to steer that!.
Oh & a turning circle of 4500 feet!! , Niiiiice !!, not to mention weekly wheelbearing changes!!
All this topped off with 12 covernotes a year insurance from Adrian S Flux ( A Snip at 4 Grand! )
Best of luck
Brian.
P.S. D.V.D. is on it's way!!
Best of luck
Brian.
Cut out your weekly bearing changes with my Brake and hub kit Brian! Oh and a custom quick rack!
Adrian Flux do love me tho. They were so nice to give me a policy.. All for less than it costs to buy the 15x8 Minilights!
marinabrian
Wheel bearings
I meant the back wheels, by the way, what are you doing with your back axle, as lobbing all this new found zetec power into a standard Marina/Triumph unit as I recall from memory, results in BANG, CHUNG, CHUNG, CHUNG, and upon checking under the car at the back, a bullet hole in the diff housing, where the crownwheel had attempted "The Great Escape"
The Triumph 'box isn't the only weak part in the marina's drivechain!
I await with bated breath
Brian. :P
Brian. :P
Three options mate..
Escourt axle with Tran-X LSD - Rated to about 250bhp
Cut down Capri 2.8 axle with LSD rated at 300bhp
Dolomite Sprint axle with Quaife LSD rated to 200bhp
It's a toss up at the moment but what ever goes in there will be one spare for the next project 8)
marinabrian
Axle
I hope you have got an idea in mind to prevent axle tramp, it spoils the fast getaway, when the whole thing winds itself up, & rips the front spring hangers off!!, 4 wheel steering on a marina isn't as much fun as you think!!.
Been there got the T shirt, the hat, & wrote the book!!
Cheers
Cheers
