Page 55 of 200
Posted: Sun Feb 09, 2014 10:14 pm
dazza2623 wrote:Got the V8 diff back in with the ventilated discs.Checking road height as well.Almost finished front coil over conversion as well.
Looking good, Darryl. :thumbup:
Are the coilovers supplementary, or have you removed the torsion bars? Rear discs factory Falcon?
Posted: Mon Feb 10, 2014 1:17 am
by ado28
Spent the afternoon in the garage doing more work on the pick up :-D
Posted: Mon Feb 10, 2014 7:50 pm
by ScreamingLordStokes
Great stuff Sean. I've been awol from here for a while so i'm looking forward to catching up with your progress.
Posted: Tue Feb 11, 2014 12:06 pm
by ado28
Cheers Tony, I have been awfy quite of late too. Working long hours mon to fri only leaves the weekends available to work on the fleet :(
Sent from my GT-I9300 using Tapatalk
Posted: Fri Feb 14, 2014 11:50 am
by dazza2623
Yes Bryan the discs are Falcon.The coil overs are supplementary .If anyone needs to know the coil overs I will be using are Koni 8211.From measurements given to me they should bolt straight on to Ital top arm with @ 5mm clearance to arm,so no need to alter that part.I will be shooting for a spring rate of @200lb,so will get an 80lb spring to use on shock to reach that approx rate required.Now I have measurement of shocks I can complete bottom brackets.
Posted: Sat Feb 15, 2014 2:12 pm
by ado28
More work on the pick up again today and will continue tomorrow. This weekend I'm concentrating on the load bed area again. So far I've welded up all the holes and ground them flush. There will be no work on the pick up next weekend as I'm off to Blackpool to do some work in a guest house but I'm on holiday when I return for a week so that should result in more progress :)
Posted: Sat Feb 15, 2014 6:03 pm
by lock1506
Are you taking Raynard down there again, it knows the way. :)
Posted: Sat Feb 15, 2014 8:10 pm
by ado28
lock1506 wrote:Are you taking Raynard down there again, it knows the way. :)
Most likely Chris, he hasn't done anything since the last show and still has English petrol in him lol
Posted: Sun Feb 16, 2014 6:19 am
by Kiwi Ute
I see you have factory P76 wheels - I had a set and gave them to an old guy who has a P76 (surprise-surprise!) and a MArina ute, he is going to (eventually) give me the wheels, dif etc from his ute as it's got all Datsun running gear now.
Posted: Sun Feb 16, 2014 11:14 am
by dazza2623
Yes I have but they were originally going to be for the Force 7v,then when that went south they put them on the Targas.I put them up to the car years ago & was impressed with the look of them on the Marina so there they stayed.
Posted: Thu Feb 20, 2014 8:25 am
by Kiwi Ute
Well...I found an old rev-counter and after a bit of fiddling I (a) got it working and (b) fitted it to the ute- Woo-Hoo! :lol:
It has a switch at the back of it, I can only guess it's to select 4,6 or 8 cylinders
I have it on 4 - I THINK (obviously!) so at 30MPH how many revs should it show?
The ute is factory stock.
Posted: Thu Feb 20, 2014 8:41 am
by PHUQ
Picked up a few bits and pieces for both the saloon and estate from that nice Mr Walsingham on Sunday morning, sadly not in a Marina. Sunday afternoon went to visit my good lady's parents, and therefore also Mud, since she's currently holidaying on their drive.
Since the sun was out for once I thought I'd see if she would start, given that it's been 4 months since she last ran & I hadn't so much as charged the battery I had my doubts, but after a few attempts she fired up and even more surprisingly was "all systems go", so we went for a cheeky spin around the block (MOT'd and insured, but not currently taxed :shh:).
Reminded me of how much I enjoy driving these things... 8-) Can't wait to get the saloon back on the road, we are making progress in that direction too thanks to Frank and Ben :mr green:
Posted: Thu Feb 20, 2014 10:12 pm
Kiwi Ute wrote:Well...I found an old rev-counter and after a bit of fiddling I (a) got it working and (b) fitted it to the ute- Woo-Hoo! :lol:
On 155x13 tyres (same for 175/70x13 or 205/60x13 tyres)
3.63 diff = 1628 rpm @ 30mph (3348 rpm @ 100kmh)
4.11 diff = 1841 rpm @ 30mph (3785 rpm @ 100kmh)
4.55 diff = 2037 rpm @ 30mph (4189 rpm @ 100kmh)
Posted: Fri Feb 21, 2014 11:31 pm
by Kiwi Ute
Thanks Bryan - I think I have a 4.55 diff as on a quick squirt out on the open road 100kph was on the 4-grand mark, it was hard to tell accurately as the badly unbalanced tyres shook the crap out of the ute at that speed!!! :o
BTW: And that's the fastest I've ever had the wee thing! :)
Posted: Sat Feb 22, 2014 8:19 am
Today I removed and refitted my front screen - using lots of sealant.
This has to be the worst job you never want to do.
I did manage it ok single handedly, but what a messy bleedin affair.!
I kept at it long enough - in 30 degree heat - to begin to see some signs of order being restored.
Only had enough insert for the top - shall find more this week hopefully.
So glad its over.. :)
