Somewhere in the history folder, there's an entry saying it had a fluid change about six months before I bought the car. I'm not looking at the folder now, but from memory, I think it was done by a garage. Probably the same garage that did several jobs on the car before I got it, including 'fixing a coolant leak'. (Radweld).
So, Mr. Rowley or whatever his name is, the previous owner, had also left, among his virtually unreadable hand written notes slotted into pages and pages in the Haynes manual he left me, something about an automatic transmission fluid leak. The garage apparently looked at it. Said the transmission was overfilled, drained some fluid out, and the leak was apparently gone. The source of the leak was deemed to be the rear seal.
So far so good, you might think. At the auction, I could not (or did not ask) to run the car as it was in an enclosed space, and I thought running the cars wasn't an option. I didn't see any other auction cars running. Later on I was told otherwise but no matter, running the car at rest would have told me little about any defects I've found later. I dipped the oil, dipped the transmission fluid, nice clean and pink, and obviously at rest, way up the dip stick.
So when I got to start using the car a little, the drip tray that used to stand under my Wolseley Hornet, with white pads on, to catch the black oil that dropped, started to acquire pink patches and under the fuel pump, little yellow patches. The yellow patches were petrol dropped at rest, after a run. Our Mr. Rowley had a diagram on a bit of paper of an aftermarket in-line fuel filter with air bubbles in it, that same filter had been removed when I got the car, the fuel pipes joined together with a union, and the filter (which I've not really looked at) is in a box of bits along with the old transmission inhibitor switch, which I have little doubt was removed and replaced because of my car's previously documented reluctance to turn over on the key, and an 'eBay' inhibitor switch is now on the car (history folder evidence) plus the previously documented 'hot wire' button under the dash, used to turn the engine over when the ignition key won't. The button is still there, not attended to yet, except now it is running it's through a 20 amp fuse so the car at least shouldn't catch fire. Near-boiling radiators and now apparently un-timeable timing have pushed their way up my priority list, past that now relatively safely fused starter button. The point of this last few lines regarding the fuel filter with bubbles in, is that I think the bubbles were down to the leaky SU fuel pump, now replaced by me with a (admittedly aftermarket) new one. I don't know how long it would have taken me to find the leak if I hadn't got my spill pads under the car, but I found it and did something about it. Instead of drawing little diagrams of fuel filters with bubbles in.
So, the pink stuff under the car. (Yes Kilroy - all you asked was 'had I checked the level?' You didn't ask me for a lecture!
) Down on my hands and knees, it is plainly obvious there is an ATF leak. Plainly obvious. Firstly, it seems to be coming from the hexagon union where the dipstick tube fastens to the side of the sump pan. Probably a taper seating, I would guess. I've tried putting a spanner on the nut and pulling (admittedly while lying by the sill - I've not been right underneath) but I couldn't budge it. I don't want to go mad and strip the alloy threads. Secondly, it is also PROBABLY leaking from the what-looks-like-rubber sump gasket, although it COULD just be fluid from the leaky union that's been blown about. Is there a leak from the tail shaft seal? Mmm - not sure. Again, I've not been right under yet. About two months into ownership, with several little drives under my belt, I decided I needed to check the ATF level, engine running, and, despite no mention in the Haynes manual that I could find, nor the car's own owner's manual, I recalled from somewhere that with my Mk1 I ran the selector up and down the quadrant in all the positions twice, slowly, to make sure fluid was in all the galleries. The level was on minimum. The car came with a full bottle of Comma mineral transmission oil, and I used half of it to bring the level up to normal. That's about a pint. So it either loses a lot, or that garage drained a pint out to 'cure' the leak. I admit that since my top up I've not re-checked the level, but then I've not been far, and until the car performs better (and with the summer season drawing to a close) I'm unlikely to.
I'm not the cleverest chap on the planet but I do get annoyed when I see such blatant oversights or bodgery taking place on motors I buy. Draining fluid out? Leak cured? I assume Mr. Rowley was either incapable or unwilling to do a lot himself, and the impression I get is the garage he took the Marina to, fobbed him off or had instructions to do things on the cheap. I've thrown his notes away. They were useless to me.
Thinking about it, I do think there were some notes about the distributor, suggesting past trouble. However, I doubt the thrown away notes would be any help, as Mr. Rowley seemed to think the car had a 25D distributor, when it is in fact a 45D.
The extra pint of fluid in the transmission made no difference to how the car drove. The jury is still out as to whether it is leaking any more.
