The history is i have done around 10,000 miles since a supposedly total rebuild and had the oil level checked around a 1000 miles ago. which it was low, so filled up. ironically it was checked and filled up because there was a hint of noise appearing, so i can only assume that the filling with oil really hasn't helped in slow increase in noise in the last thousand miles. Other than that, it's not jumping out of gear. It;s always been a little crunchy getting it into second from third, and reverse as been elusive sometimes, until i double the clutch. but largely it's been perfect in the last 40.000 miles i have put on it. (the box got rebuild mistaking it needed doing for a prop shaft bear that had gone!)
Any ideas anyone?
