Prop Shaft Troubles
Prop Shaft Troubles
Post by Morris McKinnon » Sat Apr 27, 2019 3:24 pm
The prop shaft on PTH is clonking quite badly when accelerating/decelerating and the rumble is getting worse at higher speeds. Can anyone recommend somewhere that can sort it out, or can it be done at home?
Re: Prop Shaft Troubles
Post by david painter » Sat Apr 27, 2019 4:00 pm
Should be able to fix it as usually circlip type these can be done with a socket and a vice. Centre bearing same as a Dolomite several were on ebay when I changed mine.
Post by MarinaCoupe » Sat Apr 27, 2019 5:17 pm
What he said 😁.
However, there are two types of UJ fittings, one you can do yourself with circlips like those shown in the picture, or standard internal circlips with the little holes in the end.
The rear and centre UJs are the same, the front one is different as it has a grease nipple. I’ll post the UJ part numbers later.
The second type is called ‘staked’, this is where the UJ cups holding the needle bearings are held in the propshaft yoke by peening the edge of the yoke to hold them in. They are impossible to do at home and will need professional refurbishment. There will be a local drive shaft maker/repairer in your area - someone like Bailey Morris. You’ll need to check what you have before ordering the UJs.
Post by Morris McKinnon » Sat Apr 27, 2019 5:38 pm
ok, cheers guys. Yes, PTH has the snap clips over the cup. I have seen new UJ's on line but thought I'd check here first before ordering anything. Part number would be great Chris, cheers.
Post by MarinaCoupe » Sat Apr 27, 2019 5:44 pm
Gareth here you go
Front with grease nipple GUJ 120
Centre and Rear GUJ 119
Post by Morris McKinnon » Sat Apr 27, 2019 6:04 pm
Great stuff, cheers.
Post by Morris McKinnon » Sat Apr 27, 2019 6:40 pm
I can't find anything when typing in those part numbers or the one with a grease nipple, but plenty of the sealed for life ones around. Same as Hillman Hunter and Avenger.
Post by Gee tc » Sat Apr 27, 2019 9:09 pm
Or if adventurous...
A transit one... with a bit of light mig work for the centre bearing
Post by david painter » Sun Apr 28, 2019 8:55 am
I have had a quick look around GUJ115 is listed for Dolomite MGB MG Midget & Triumph Spitfire/ Herald, so may well have changed part number. The link below are UJ manufactures the site allows you to search by Size
https://www.ims-ltd.co.uk/products/sear ... al-joints/
Post by Morris McKinnon » Sun Apr 28, 2019 5:25 pm
Very likely. The measurements are 2.382 for the cup and 6.130 joint diameter, Dolomite is same. Same as Morris 8, 10, and 12 apparently.
Post by ScreamingLordStokes » Sun Apr 28, 2019 11:17 pm
If you are going to do the work yourself, fine.
However, if you are using a propshaft refurb company make sure they are OK using the UJs that you buy, the place I used insisted on using UJs from their own stock as they didn't trust the UJ I supplied ( even though it was a brand new GKN one).
Post by Morris McKinnon » Sun Apr 28, 2019 11:25 pm
ScreamingLordStokes wrote: Sun Apr 28, 2019 11:17 pm If you are going to do the work yourself, fine.
ok, thanks for the heads up. I'll do it myself, unless of course the prop is damaged, though I don't think it is.
Post by david painter » Mon Apr 29, 2019 7:20 am
I can understand the machine company not fitting customer supplied parts. Legislation is to blame and the lets sue culture. I don't fit customer supplied parts for two reasons firstly is the ramp down time if it is the incorrect part with poor quality and take much longer to fit. Secondly the Garage once it is fitted as deemed it to be suitable and of satisfactory quality and then become responsible for the warranty not only for the fitting but the part as well. Crazy I know but that's how it is.
