Polyurethane bushes
Polyurethane bushes
Post by martinclan » Fri Mar 10, 2023 4:37 pm
Has any one else tried fitting polyurethane bushes to the front suspension eye? The one that mounts the lower arm to the chassis.
The bushes I have (Superpro?) have a substantial shoulder on either end making it pretty much impossible. With other cars that I have used this type of aftermarket bush on they have been split - that is you insert them in two halves, one from either side.
Cheers, Robin
Re: Polyurethane bushes
Post by MarinaCoupe » Sat Mar 11, 2023 9:18 am
Yes I have them on my Coupe. I left them in very hot water for a good half an hour and I used some of the assembly grease inside the eye to make it slipperier.
I then got some threaded stud and nuts, together with two big and thick penny washers. One washer goes behind the bush and the other on the opposite side of the eye bolt. The stud goes through the bush and eye. Then I progressively tightened the nuts down and it pulls the bush into and then through the eye.
Post by martinclan » Sat Mar 11, 2023 12:05 pm
Thanks Chris
I'll try that. I have used that method before on orher occaisions but the bushes felt so rigid I just couldn't see it working. I think I probably need to warm them up more....
Cheers Robin
Post by locost_bryan » Sun Mar 12, 2023 10:05 pm
Kelvin has detailed photos of how he did it in his Full circle into a Marina again. My 73 Morris Marina Coupe thread.
Post by Gee tc » Sun Mar 12, 2023 11:11 pm
I did my own in a vice with warmth and patience. No probs.
T
Post by martinclan » Mon Mar 13, 2023 10:43 am
Thanks all
In the end, much to my surprise, it proved easy. I used the threaded bit from an old 3 leg puller which has an acme thead (better for pulling than a normal thread)
Soaked in very hot water first and plenty of the supplied grease.
Imagesuspension eye bush 1 by Robin Martin, on Flickr
Imagesuspension eye bush 2 by Robin Martin, on Flickr
Post by PHUQ » Mon Mar 13, 2023 12:22 pm
You've reminded me, I have another one of these to do...
Post by MarinaCoupe » Mon Mar 13, 2023 3:27 pm
Robert is your close relative.
Mandator
Post by Mandator » Sun Oct 06, 2024 8:14 pm
Talking about Poly bushes... Kermit still has a knock on the nearside front and I suspect the rubber bushes are on the way out. My garage has checked out the suspension but everything "seems" OK so am thinking Poly bushes might be the way forward.
What Poly bushes are suitable for my Mark 3 1300 Saloon? I read Dolomite bushes fit but would like a confirmation before buying. Or, if other types are a better fit, what do others suggest, (preferably with reference numbers)?
Mandator
Post by Mandator » Sun Oct 06, 2024 8:44 pm
Doh! Just found the appropriate info on the technical site!
Blame senility:)
