Gaskets
Gaskets
Post by martinclan » Thu Jan 02, 2025 9:27 am
I am collecting together the final few bits I need prior to refitting the B series engine in my Marina based Marlin Roadster and I am missing a couple of gaskets.
1. Engine block to rear mounting plate
2. Gearbox body to bellhousing
Does anyone know if these are still available and / or have part numbers for them?
Cheers, Robin
Re: Gaskets
Post by MarinaCoupe » Thu Jan 02, 2025 9:52 am
The gearbox to bellhousing gasket is normally included in the gearbox rebuild kits available, you may find it separately listed for Triumph Dolomite, TR7 or Spitfire. The engine block to backplate would be part of the B Series bottom end conversion gasket set, you may find it separately on one of the MGB online shops.
