front tie bar bushes
Posted: Wed May 28, 2008 9:52 pm
by stuthegasman
is there anything similar that can be bought from a local motor factors as Ive just realised these need changing before the mot
Posted: Thu May 29, 2008 8:42 am
by ClaytonSpeed
Get them direct from Superflex! They do next day delivery. Failing that if you are really stuck I have seen people use the rear damper bottom bushes.... Not really a good idea!
Posted: Thu May 29, 2008 8:54 am
by stuthegasman
just seen some mini tie bar bushes and they look similar would these do as my local factors probably stock these on the shelf
Posted: Thu May 29, 2008 9:01 am
by ClaytonSpeed
Maybe... I imagine they would be a slightly smaller diameter but it's got to be better than what you already have!
Posted: Fri May 30, 2008 11:26 am
by d13ker67
I have just got some from superflex they where £16 delivered in two days
Posted: Fri May 30, 2008 1:27 pm
by martinmarina
Hi Stu
I know Paul uses mini bushes on his mk1 mk8, I got mine for the mk3 from superflex for £17.00 inc postage .
Posted: Fri May 30, 2008 7:33 pm
by Muskydo
Hi, last year I was in a similar position, in desperation I bought a set of Mini bushes only a few quid,fitted them and Pickup aced the MOT. This years MOT done all the normal pre-checks,then went for MOT, whilst under the ramp with the tester I noticed the Mini bushes that I fitted the previous year still looking as good as new. I have had no problem with these bushes and therefor forgot all about them.Pickup once again I'm pleased to say aced the test yet again,NUFF said me thinks.....
Steve
