Rear leaf spring rating
cowboybob
Post by cowboybob » Thu Jul 12, 2007 11:19 pm
Can anyone advise on rear spring rating's.
Just Building up the rear end on the "plastic" marina and I'm a little concerned over the stiffness of the spring's. These are a 3-leaf springs and was wondering if the 2 leaf was ony softer (seen some on e-bay) or does anyone want to swap (these are like new). Has anyone got the weight rating for these springs. The rear of the car is so light it can be lifted up single handed without the body on, but then the car only weighs 650kg fully built anyway.
Many thanks in advance.
If it ain't broke take it apart anyway,at least you will know how it works when it does break.
Post by MarinaCoupe » Fri Jul 13, 2007 1:02 pm
From memory - the three leaf springs are 130 lbs and could well be off an estate.
Most of the two leaf springs are 113 lbs and will be from a saloon or coupe. There are a few 'heavy duty' two leaf springs about (rare in the UK but standard fit in some export markets), they are rated at 130 lbs.
If your existing springs are estate then fitting saloon/coupe springs will create a lower ride height as the estates were designed to ride higher.
cowboybob
Post by cowboybob » Fri Jul 13, 2007 11:44 pm
Thanks for the info. Will give you a call Elouse when I get 5 mins and the hour isn't too late. Many thanks for the offer of the swap. May take you up on the offer, would need to check the ride hight though with the body back on.
