BL parts# help identyfying
Posted: Sat Aug 25, 2007 9:51 pm
by norway_triumph
picked up 3 rubber list - all with "felt-like" material on the inside
37H6026 - handwritten Marina on it but i can't figure out where it goes
DZB5696 - similar rubber but wider
DZB4280 -similar
anyone who can identify them ?
Posted: Mon Aug 27, 2007 10:26 pm
Hello, I found your part 37H6026! According to my list it is a Channel Glass run and is fitted to the rear doors of saloons and estates. Not clear from picture but I think it goes either on the inside or outside of the opening rear door window. If it is mainly rubber then it will be outside but if more fluffy and thin then the inside clipped to door top behind the top vinyl door capping against window.
I hope this helps!
Sorry can't find other two numbers for 1971 to 1978 so my be Ital!
Cheers,
Posted: Tue Aug 28, 2007 5:25 am
by norway_triumph
Thanks Paul
Checked it out and yes it goes on inside the door with the fluffy end facing the window. The two other channel rubbers i don't think they are Marina as they are a bit wider.
