rpm low in drive
AustinMarina
rpm low in drive
Post by AustinMarina » Thu Aug 30, 2007 4:26 pm
Can someone tell me why when the engine is working in neutral the rpm is around 900 working ok and once I put in drive rpm falls?
The problem is that when Iam waiting at traffic lights because of the low rpm in drive the engine stops :x
Every thing is almost new, even carb is rebuild, but this still seams to be my biggest problem and I cant enjoy the car.
AustinMarina
Post by AustinMarina » Fri Aug 31, 2007 5:08 pm
Thanks mate, but still at 1100rpm we have a problem once we put it in drive :?
madmart
Post by madmart » Sat Sep 01, 2007 3:11 am
has the auto box been repaired or altered?
Post by Kilroy » Sat Sep 01, 2007 7:50 am
As the carb has been rebuilt, perhaps the mixture is a bit weak - so the extra load on the engine caused by being in drive is causing a much greater rev loss than is normal..?
How is it with a small amount of choke on..?
All autos lose a few revs when going from neutral to anything - but it should only be a few hundred.
Luck,
