gary
Auto darkening welding mask ?
Hello all, been looking at the auto darkening welding masks on ebay £26 ,anyone bought one used one.
gary
gary
1978 1300 coupe sorn (work in progress)
1975 Suzuki T500m sorn
1967 morris traveller modified in bits !
- jiversteve
Re: Auto darkening welding mask ?
Have seen them and used one but am wary of cheap versions. Has the one you are looking at got an adjustable darkness control so you can set it for gas or arc welding?
I have a standard welding mask but its too dark for me and I was looking for an Auto Darkening one.
Keep us informed if you buy.
- MARINAMAN480
not used ones off ebay . But i have got a MAC tools one and it is fantastic makes welding so much easier
yep got one think it cost around £40 well worth it ,
Rob. :mrgreen:
Rob. :mrgreen:
1981 Ital hl 1.3
1982 ital slx 1.3
1983 bmw r80rt
1975 honda cb 550 hard tail chop
1967 vw split screen camper
1991 mini cooper
1991 honda cg 125
1982 ital slx 1.3
1983 bmw r80rt
1991 mini cooper
1991 honda cg 125
Hello all,
I got one costing £25 plus £5 postage,had a go at some scrap metal earlier and apart from having to replace the two AAA batteries,it's solar with battery back up. it's working a treat.looking in the specs it doesn't state it can be used for gas welding,just tig,MIG,plasma cutting and smaw, shielded metal arc welding.
I will post more when I have had a good welding session.
Not sure but is it not the speed of it darkening which enable its safe use or you end up blind! So if it can handle tig or arc etc then gas should be OK unless Gas welding gives off a particular light spectrum which the filter can't decrease to a safe level.
Hello again,
Just had a good 15 minutes welding with the new mask and it's spot on for the money,clear vision big enough window,strike up and the screen darkens in a split second brilliant stuff.
I remember years back when I had ,had a a flash off arc welding , can't remember how it happened but I was fine until I awoke in the early hours of the morning,my eyes felt like they had sand in them,horrible condition arc eye.
Think I was using a welding glass where the top corner had snapped off and had no spare.
Gary
Gary
