wiper arm
Posted: Fri Sep 07, 2007 4:15 pm
by dandaz
Hi
The signals on my wiper arm are upsidedown.... :shock:
Also it has come out of his splinned socket ,is it the original?
marina 1971 .....
Posted: Fri Sep 07, 2007 4:19 pm
by dandaz
Also what is the best additive to put in your petrol ,I have been using the syringe thing on bay but are a bit expensive... :(
Posted: Fri Sep 07, 2007 4:22 pm
by Becks
We dont put anything in the petrol but on the island they do low mileage
Posted: Fri Sep 07, 2007 4:45 pm
by ado28
You can use Castrol Valvemaster which you can get from any Halfords if you wish to use an additive
Sean
Posted: Fri Sep 07, 2007 6:33 pm
by JIM73
I found my TC ran better without the stuff !!! :|
Posted: Fri Sep 07, 2007 6:35 pm
by JIM73
Also can you post a pic of your wiper switch :?:
Posted: Fri Sep 07, 2007 9:46 pm
by dandaz
So I can put unleaded straight in?
I will get a picture of wiper switch when it gets light....
Many thanks....
ooooops did I mention , I love driving the Marina... :D :D :D
Posted: Fri Sep 07, 2007 10:31 pm
by ado28
It wont be a problem running it on unleaded as long as you don't give it a thrashing. There should be enough lead memory on the valves to keep it running smoothly. I use super unleaded when possible and all of my classics don’t seem to complain (well all the petrol ones anyway!)
Posted: Sat Sep 08, 2007 8:23 am
by norway_triumph
i always use a lead substitute additive. i remember reading an article about "lead-memory" on the valves when leaded petrol was phased out. i think the article said that the led-memory could last as short as 2000/3000 miles...
Posted: Sat Sep 08, 2007 8:37 am
by dandaz
Cool I will put additive in now and again...
My indicator....
Posted: Sun Sep 09, 2007 10:41 pm
by JIM73
Looks like you need a new one !!! :shock: Thats been well bodged up !!
Posted: Sun Sep 09, 2007 11:01 pm
Hi Dandaz, Ref your wiper arm. Looks like you may have a LHD or one for a different car!
What ever you do it will be up side down unless it is on the other side of the steering wheel!
Is the plastic part split where the metal splind arm fits? Only if not they can be pushed back in but you need it off the steering colume and pop the end cap top off and use a jig to protect the contacts and push it back in the correct orientation.
I have rebuilt my head lamp side as I had no black sleeving on my arm and it would not stay on main beam due to broken plastic clip, but all fixed by using a non marina arm stripped down to rebuild my original arm.
A bit fiddly to do, so only do it if you like that sort of thing :shock:
Wiper ones are abit more tricky to push back in compared to headlamp ones as hole is at an angle!
Good luck,
Posted: Mon Sep 10, 2007 7:56 am
by dandaz
Hi
Thanks for your reply....
The metal piece has broken so it`s nackered.. :?
My hand seams to wack it every time I turn the wheel...
I will look for another one..
Cheers.. 8)
