Part number help needed
Chicken Hawk
Can anyone help me with this part number please? CZK 8263 Its a window rubber but im not sure if it is just a plain rubber seal or if it has inserts for a chrome/plastic strip? Thanks in advance
Re: Part number help needed
All Marina/Ital front and rear windscreen rubbers have an insert for a trim strip.
Mk1s used a stainless steel strip, later cars mostly used a chrome plastic filler strip and some cars used a black plastic filler strip.
The profile for the plastic filler strip is the same as a real Mini, so readily available. ADZ if you are struggling to find some, speak to Frank, he'll probably have what you need.
Hi Chris...just a quick correction on the infill strip in case everyone goes rushing out to buy Mini infill strip..DONT it is different, the Marina screen insert is a `D` section insert, the mini is more of a `V` section, the Marina section is available from COH Baines Ltd directMarinaCoupe wrote:All Marina/Ital front and rear windscreen rubbers have an insert for a trim strip.
Hi Adz,
If that part is from Voking2000 he has some good rubber seal parts!
I think he was the chap I bought a saloon rear screen seal off and it was a gen part which had the correct shape for the wide stainless insert! I got him to send a close up picture.
I understand looking at my parts list and the picture it is a coupe rear screen seal and not the pressure strip or screen etc.
With that part number I would not think it will be a rubber seal with no insert moulding.
Good price too!
Hope that helps
Good price too!
Hope that helps
I stand corrected by the President.
8) Makes a change Chris!...you`re usually spot-on mate
Chicken Hawk
Cheers for the help chaps,just waiting for it turn up. Will let you know the outcome!
Chicken Hawk
Well it turned up today and its just as he said,a new rear window rubber for a coupe
Thanks for the help guys 8)
Well done Adz!
This guy has some good stuff as I said.
Original gen rubbers for MK1 are not easy to get now.
- Coupedriver
Any more of those around? I'd love to get my hands on a couple. Skip
MarinaMan
Keep an eye on Ebay! This guy does have good windows seals etc but I have no idea if he has any more.
these are like rocking horse poo! :roll:
- Coupedriver
I can't find him. Can someone send me some sort of link or search topic. Thanks, Skip
