Water pump...
Water pump...
...is donald ducked.
Anyone know the part number for the 1.3 offhand?
Or got one they don't need?
ta!
Mick
ta!
Mick
Re: Water pump...
mikmik,
There are two types, depending on whether you have the fluid driven fan or not. As it happens I have an earlier one, which I bought by mistake some time ago, if you are interested?
Re: Water pump...
I'll get back to you mate, thanks a million - there's a guy in Dublin has one too
Obviously thats nearer!
Re: Water pump...
Which one is the earlier one, marinacoupe?
Re: Water pump...
the 1300cc A series (with the bypase hose ) is the same a mini should be abel to get one in fistline for £30 ish
Re: Water pump...
mikmik
The early one doesn't have the fluid driven fan. You can have it for £15 plus the postage.
PM me if you are interested.
Re: Water pump...
Thanks lads. My Dublin contact came good and dropped it off to work for me yesterday.
It'll be going in tomorrow.
Thansk for getting back to me though lads.
Much obliged
Much obliged
Re: Water pump...
Can you explain what this means I might be a bit slow here :shock: Reason I ask is I have a 72 Coupe that needs a pump and now I dont know which to get. Would the one you have fit?MarinaCoupe wrote:
Sorry for the thread Hijack
Mick
'66 Landrover Doublecab TDi
'72 Marina 1.3 Super Coupe
'87 Cavalier SRi
'04 Vectra
'87 Cavalier SRi
'04 Vectra
Re: Water pump...
Hi Mick,
It's how the fan is fitted to it, your should just have 4 threaded bolt holes on the plate that mounts the pulley and fan, like below.
ROVER/MG ROVER Marina 1.3 WATER PUMP FWP1115
The late ones look like this
The difference is in the position/size of the impeller and the fan mounting points.
Try this Ebay link, it brings back all the different 1.3 waterpumps with the appropriate years.
Ebay Search
I still have my pump if you want it, but can't post until the weekend.
Ebay Search
Re: Water pump...
Thanks for the info Chris, No mad panic on getting the pump im still away from home until may. Im prety sure the car is correct for its age but without actualkly chcking I cant be sure. If its right and you still have it I will give you a shout when I get back.
Mick
'87 Cavalier SRi
'04 Vectra
'87 Cavalier SRi
'04 Vectra
