Clutch Fluid Reservoir
Posted: Tue May 18, 2010 6:56 pm
by Billy Shears
Dear All
My clutch reservoir is bone dry and a wet patch has appeared under the car
Any ideas where it could be leaking from and is this a common fault?
Car is a 1974 1.3 Coupe Manual
Thanks, Bills
Re: Clutch Fluid Reservoir
Posted: Tue May 18, 2010 7:07 pm
Well if it is outside the car and not on the carpet, then I would imagine the slave has leaked unless you have a hole in the clutch pipe!
Posted: Tue May 18, 2010 8:14 pm
by Billy Shears
Many Thanks
Where can I get a new clutch slave from?
Thanks
Posted: Tue May 18, 2010 10:44 pm
The Club is reconditioning them I think, you need to speak to Chris Weedon (Marinacoupe)
Failing that Ebay normally has a couple but prices are going up!
you should be able to verify where the fluid is coming from first by jacking up the car and checking for damp seals on the slave. If there are drips there then that is probably the problem :wink:
