gjmc525d
Post
by gjmc525d » Tue Nov 01, 2011 6:19 pm
I have bought a spigot bush for my Jubilee engine but now need to source the outer sleeve ,does anyone know where I can buy one new .
Tried a couple of suppliers but no luck.Does an Mgb engine have the same spigot bush set up?
Any info would be gratefully appreciated
2023 Skoda Enyaq Sportline
2925 Alpine A290
1974 Morris Marina TC Jubilee
Post
by MarinaCoupe » Tue Nov 01, 2011 6:47 pm
Marina B series 1.8, standard gearbox spigot 1/2" diameter. Standard Marina crankshaft 3/4" diameter, so bush should be - 1/2" ID & 3/4" OD.
Earlier Mgbs had a bigger hole in rear of crank, but never fitted by BL to Marina.
www.marinacoupe.co.uk
Coupedriver
Post
by Coupedriver » Thu Nov 10, 2011 8:16 pm
Chris: Did the info in my PM help? Skip
MarinaMan
Coupedriver
Post
by Coupedriver » Thu Nov 10, 2011 10:27 pm
Oops, it was for gjmc525d--I thought he was Chris. Sorry--I need a keeper...
Skip
MarinaMan
gjmc525d
Post
by gjmc525d » Fri Nov 11, 2011 2:11 pm
Thanks for all the info,hopefully will get something sorted
2925 Alpine A290
Post
by MarinaCoupe » Mon Jun 11, 2012 11:21 am
Did you get this sorted out? I need the big bush for my T16 conversion. If yes where did you source it?
Post
by Kilroy » Mon Jun 11, 2012 9:35 pm
I had the same requirement when using a crank from an auto for a manual.
As no bush had ever been fitted, there was a large hole in the crank. I asked the engine reconditioners if they could make one, but they said it would be too difficult/expensive/something to do so from bronze.
Instead, they made a steel spacer, and the original bronze bush fits in that.
I did supply a crank with a bush already in it - but they could not get it out without destroying it.
Hope that is of interest.
Post
by MarinaCoupe » Mon Jun 11, 2012 9:49 pm
LeacyMG in the Uk has them on back order. They are having 300 made, but they will be about 2 months, so I have resigned myself to getting a local engineering co. to make me one. I had come to the same conclusion as you and was planning a steel bush to take a needle roller spigot bearing.
Mine will have to be a Frod bearing to match the gearbox though.
Post
by martinclan » Mon May 16, 2022 6:49 pm
Old thread this I know. But did anyone locate a source for the spigot bearing. I looked at the above mentioned Leacy Web site and they don't list them, or anything else for the Marina!
Cheers Robin
Post
by martinclan » Tue May 17, 2022 10:04 am
Thanks Chris
So I assume this is an alternative as it seems to be a Land Rover part. I can see it is a needle roller bearing which is going to be superior to the original which I believe was a oilite style bush?
Cheers, Robin
Post
by martinclan » Tue May 20, 2025 9:13 am
Just returning to this subject. I bought a needle roller bush from a well know classic car pars supplier. It has the correct part number but, slightly worrying, says made in Taiwan on the label...
To cut a long story short I thought I would test it for a fit on the gearbox input shaft before I pressed it into the crankshaft. It is a very, very loose fit. Is that normal? Perhaps it will be better once it is pressed into the crankshaft which must compress it slightly?
Cheers, Robin
