Rear wheel bearings
ct90dave
Rear wheel bearings
Post by ct90dave » Sun May 06, 2012 10:52 pm
I need to replace the rear wheel bearings in my wagon. Just wondering if anyone can point me in the right direction with regards to the size I need to order. Would rather not have it in bits before I have the parts to fix it. If someone knows what bearing I need to order that would be a huge help.
Thanks Nigel
KD66 1981 575 van (Work in progress)
KX1431 1982 Morris 1700 station wagon (Daily driver)
ARP997 1979 Isuzu Journey Bus (Holiday Accom)
MYVSV8 1996 HSV Clubsport 5.0V8 (Toy)
CCN375 1996 Nissan Largo (Family Wagon)
1971 and 1974 Honda CT90 Farm Bikes
1990 Suzuki LTF250 Quad
Re: Rear wheel bearings
Post by JoshWard » Sun May 06, 2012 11:20 pm
They're the same as TR7 4 speed ones if that's any help, no idea where you can get 'em out in NZ.
Here's a link to Rimmer Bros where I got mine from:
http://www.rimmerbros.co.uk/Item--i-GHK1030
Post by MarinaCoupe » Mon May 07, 2012 8:22 am
Kilroy will be along in a while, he'll be able to point you at Marina parts in NZ.
Post by Kilroy » Mon May 07, 2012 8:53 am
You rang Sir..?
The QH part number for a complete rear wheel bearing kit is QWB133C.
I bought a few some years back - have not tried to source any more yet.
The bearing itself is either SKF 6206, or RHP N9661A - its a pretty common size.
The kit has the bearing, 2 seals, and a gasket. 1 seal fits in the housing behind the bearing and seals on the half shaft, the other fits in a plate outside the bearing and seals on the hub.
Usually you can get away with using them again - but if you get cranky when trying to pull the hub off you can destroy the outer one quite easily...
Cheers
ct90dave
Post by ct90dave » Mon May 07, 2012 10:31 pm
Thats awesome, thanks for your replies. Having the part number of thew bearing is what I wanted, thanks Kilroy.
