Gold Seal Engine
Posted: Sun Nov 04, 2012 8:13 pm
by welshrat
Good evening all, new here, just a few questions if thats OK.
Picked up an Ital 1300 engine today that is painted gold. I am aware of the Gold seal and Silver seal replacement units but thought that this service was discontinued well before the Itals came into production. Engine number is BHM1266 ET12029, any information on this engine or general info regarding BMC's engine reconditioning service would be great.
Re: Gold Seal Engine
Posted: Sun Nov 04, 2012 8:30 pm
by JoshWard
Definitely check it out inside before use is my advice. Where my dad used to work got a batch of new gold seal engines for their vans one year. They were full of silt and gunk!
Posted: Sun Nov 04, 2012 8:46 pm
Gold seal engines and gearboxes were produced well into the 1980s.
www.marinacoupe.co.uk
Sent from iPhone
Posted: Sun Nov 04, 2012 10:48 pm
My original Jubilee had a gold seal engine fitted after the old one wore out or was very tired. The problem was they fitted the oil control rings on the pistons the wrong way up.
this let oil through every now and then until the bores were like a black mirror. Then it was like Bonds 007 DB5 but in a random fashion letting half a pint of oil out out any one time.
This made the cars behind disappear instantly.
Great if you wanted to loose a tail
Take it apart and check everything.
Easy while engine is out.
Same with a gold seal gearbox.
Gold seal was meant to mean new and silver seal reconditioned.
Posted: Mon Nov 05, 2012 5:07 pm
by Martec
At 60,000 miles I bought and fitted a goldseal engine from a BL agent, at 120,000 miles -ish I took it out and reconditioned it and found steel liners to bring it back to stanard bore size and standard size pistons fitted plus over size main and bigend bearings. I still have this engine ready to refit if legislation forces it upon us.
Posted: Mon Nov 05, 2012 8:41 pm
by MARINAMADBAZ
morris ital 1.3 gold seal engines.
this information took from a unipart gold seal engine and gearbox book
BHM1266E,BHM1462E,BHM1267E,BHM1463E
BHM1266E refers to manual HC engine
engine numbers
12VE923E/H101 TO 053932
12V924E/H ON
12V936E/H
12V937E/H
12V938E/H ON
12V939E/H ON
Best regards
Barry
