http://www.ebay.co.uk/itm/SHERPA-LEYLAN ... true&rt=nc
bargain!
Best regards
barry
Power :-MarinaCoupe wrote:I think that it's the torque that f**ks gearboxes and axles, so your point about sensible acceleration is important. BL had to assume that customer would use the extra torque and power and would as a standard assume a level of over-engineering to accept the forces of a 2.0 litre to withstand say 80k miles before rebuild, to avoid warranty claims.
Even the Dolomite 1850 with 91 bhp and 105 ft/lb must have been pushing the limits. What was the donor for the o/d gearbox you first tried, or was that a late Spitfire?MarinaCoupe wrote:Good research Bryan,
BL blunted the torque and power of the 2.0 litre Ital with the auto box (side stepping the manual gearbox problem), and protecting the back axle in the process. Also by keeping her as a single carb they could strangle the O series potential.
The Marina box was originally designed for the 1200 Triumph Herald, the updates helped but essentially the basic main bearing sizes and gear set dimension were defined in the late 1950s / early 1960s.
The TR7 went from the same gearbox to the LT77 as the Triumph engine was pushing out 135 lb/ft of torque and needed a more capable gearbox as well as a fifth gear.
