'Intermittent' wipers????
Kiwi Ute
Post by Kiwi Ute » Sat Apr 27, 2013 6:43 am
OK, not sure if this is in the right part of the forum but:
At times lately I have turned on the wipers in my Marina ute and there's been no action from them - or they started working several seconds after I turned them on.
When it appears they weren't going to work I have turned them off and tried again - and on this 2nd attempt they generally started right up (but not always!)
Any ideas what is happening? - and why? :?: :crazy:
dazza2623
Re: 'Intermittent' wipers????
Post by dazza2623 » Sat Apr 27, 2013 10:13 am
Could be dirt build up in wiper stalk\switch.Give it a clean .
Marina 6 one day,V8 the next
Kiwi Ute
Post by Kiwi Ute » Sat Apr 27, 2013 10:18 am
dazza2623 wrote:Could be dirt build up in wiper stalk\switch.Give it a clean .
I'll have a look at the switch on the dash as my stalk only functions as horn/indicator/hi-lo beam switch, thanks :thumbup:
Post by MarinaCoupe » Sat Apr 27, 2013 11:27 am
I agree it sounds like dirty contacts, try the switch first. If that doesn't cure it then look at the breaker/park contacts in the wiper motor box.
Post by Kilroy » Sun Apr 28, 2013 6:54 am
One of my cars occasionally exhibits a "no wipers" condition on a cold morning.
I discovered that it was actually the ignition - the key was not returning properly from the "start" position, so a number of electrical items would not work.
Some WD40 in the barrel of the ignition switch cured it.
Doesn't cure ugly chics though...
dazza2623
Post by dazza2623 » Sun Apr 28, 2013 9:15 am
No but bucket loads of alcohol does.
Marinanut
Post by Marinanut » Sun May 05, 2013 5:18 pm
dazza2623 wrote:No but bucket loads of alcohol does.
.... Cheers pal, just washed my PC screen with a mouthful of tea! ;)
