Hi all,
Does anyone know the size/thread of the tappet adjuster nuts on the 1275cc engine? I have one with a partially stripped thread and would like to buy some, but cant find them. If anyone knows where I can buy these please let me know.
thanks
Tappet adjuster nuts
Re: Tappet adjuster nuts
don't know the size but will think mini-spares/minimania and similar mini-specialists have them
- minispeedstar
From memory they're 5/16unf
Earlier ones were 7/16
There are three different types dependent on the age of your car/engine. BL changed the design of the tappet rocker and the tappet screw with it. As the 1275 Mini engines of the same period shared the same parts there is a readily available supply.
The tappet rockers will be one of these three designs, once you have identified the tappet rocker design I can tell you the part number of the tappet screw.
1. A pressed steel style where BL just squeezed a thick metal tube flat.
2. A cast type that still shows the casting surface on the parts that aren't machined.
3. A billet style from sintered steel which looks like it has been machined from solid steel.
If you are not sure post a picture of your rockers in situ and I'll let you know.
- minispeedstar
These are used with the sintered type rockers
https://www.minispares.com/product/Clas ... |Back%20to
www.somerfordmini.co.uk list all three types with different part numbers for each type of rocker and each type of matching tappet screw.
