8 inch rear drums
jcordhume
8 inch rear drums
Post by jcordhume » Wed Sep 18, 2013 6:48 pm
Just been given a rear axle which i believe is from a marina, however its got 8 inch rear drums, did they use this size of rear brake drum on any year/model of marina. If so does anybody know where i can get a good condition 8 inch drum to replace the one that is badly scored?
Thanks
Re: 8 inch rear drums
Post by MarinaCoupe » Wed Sep 18, 2013 7:13 pm
Can you post a picture to confirm which axle it is. It would then be possible to confirm that it is Marina/Ital. There were two axles, the Saloon, Coupe, Estate and 7cwt/440 Commercial used one axle and a different heavy duty axle was used on the 10cwt/575 Commercial.
The 8" (203mm) drum Marina/Ital axle is the Saloon, Coupe, Estate and 7cwt/440 Commercial one. The same axle was used with different brackets on the Caterham 7 (Ital based), Triumph Dolomite and Triumph TR7.
Post by ClaytonSpeed » Wed Sep 18, 2013 7:45 pm
Any good machine shop should be able to recut the drums for you. Might be what we all have to do one day :-(
Post by MarinaCoupe » Wed Sep 18, 2013 8:06 pm
As Ben said, your local machine shop will skim the inside of the drums for you.
Alternatively try this for a new one from TR7 on Rimmer Brothers website.
http://www.rimmerbros.co.uk/Item--i-GDB101R
jcordhume
Post by jcordhume » Wed Sep 18, 2013 8:19 pm
Will post a pic when i get back at the weekend, I was kind of hopping that i could get a new or second hand one as i think this would be past re-machining as the score is about 20mm wide and about 5mm deep not to mention the cost!!
Post by MarinaCoupe » Wed Sep 18, 2013 8:36 pm
Follow the link to Rimmer Bros above.
Post by locost_bryan » Wed Sep 18, 2013 10:44 pm
One on fleabay here, 21H 5136, title says "MORRIS MARINA REAR BRAKE DRUM" but description says "MORRIS MARINA FRONT BRAKE DRUM". Were the front and rear drums the same? :-?
Earlpart have them listed here, at an eye-watering 56.61 :o
jcordhume
Post by jcordhume » Sun Sep 22, 2013 12:18 pm
Well I would post a photo of the axle but can't work out how to!! I now also have a problem with the brake cylinders as all the ones i seem to find are different to the ones on the axle. Also if i ever get these brakes rebuilt how do you adjust them?
Thanks
Post by locost_bryan » Sun Sep 22, 2013 11:22 pm
jcordhume wrote:Well I would post a photo of the axle but can't work out how to!! I now also have a problem with the brake cylinders as all the ones i seem to find are different to the ones on the axle. Also if i ever get these brakes rebuilt how do you adjust them?
Thanks
There's a "How To..." here.
Two ways to post photos.
1) Attach to your message - when you're typing in your message, you'll find the Attach tab/button below the message "window", browse for your photos and click "attach".
2) Upload your photos to PhotoBucket or flickr, then paste a link in your message (click the "Img" button above the message "window", "img" and "/img" tags will appear in your message, paste the photo's url between those "img" and "/img" tags. Even easier, Photobucket will generate the code for a thumbnail link to your photo for you, then you just paste that code into your message. That's what I do. :thumbup:
