Page 1 of 2
Dating TC engine/ translating engine number
Posted: Thu Oct 03, 2013 7:02 pm
by PHUQ
Been meaning to do this for a while...
Bought a TC engine for the estate about 18 months back, and I was wondering what age roughly it was. Anyone any ideas? It's original car is long gone- it was extracted from a rotten car for a kit car project that never happened.
The engine number is 18V E-180850
Be interesting to compare to what other folks have & see if we can vaguely date it. I suspect it's relatively early, as it had an inertia- type starter, but I've no idea when that changed.
Posted: Thu Oct 03, 2013 8:17 pm
OK anorak time, your engine number is actually
18V 408E - H180850
18V = 1800cc Verticle (in line)
408 =
Lucas 16ACR or 17ACR alternator with negative earth
Mechanical fuel pump
Pre-engaged starter motor!!!!!
Centre change gearbox
E = Carb crankcase ventilation
H = High compression
Engine numbers started at 101
I can't tell when the starter motor was switched over.
Re: Dating TC engine/ translating engine number
Posted: Thu Oct 03, 2013 8:33 pm
by PHUQ
No comment :lol:
Cheers Chris, that's great 8-)
Quite surprised there's nothing to denote it as a twin carb motor... or was it not originally?
Interesting on the starter motor :lol: dont take anything for granted on a 40yr old engine...
Posted: Thu Oct 03, 2013 8:37 pm
There is a twin carb indicator in the chassis number. TCs have a "T" in the code .
Posted: Thu Oct 03, 2013 8:57 pm
by PHUQ
Ahh. Wondered if the engine would have one too...
Chassis number is another matter entirely... Is body type (Coupe/ saloon) covered in the chassis number? Guess it must be.
Would still be interested in where other folks' TC engine numbers are relative to this one, so I can get a very rough date (don't want to know your actual numbers, just "mine is about 2000 less and is 1974" would be ace ;) ).
Posted: Thu Oct 03, 2013 9:29 pm
Chassis nos.
TC Saloon = MH/4S9T - xxxxxx
TC Coupe = MH/2S9T -xxxxxx
4 = 4 doors (Saloon)
2 = 2 doors (Coupe)
Posted: Thu Oct 03, 2013 9:34 pm
by PHUQ
8-) Cheers Chris. Now to see if I can get a chassis number...
Posted: Thu Oct 03, 2013 9:36 pm
The 408E part engine number suggests a single carb engine.
Twin carbs should have a C, F, T, W, X, Y, Z as part of the engine code.
Posted: Thu Oct 03, 2013 9:42 pm
by PHUQ
That makes a bit more sense, I thought that there should be an identifier in there somewhere. Doesn't bother me either way, it's got the right carbs & manifold at least (and is a high comp, big valve head engine)- just interesting.
Going for anorak Gold star now. If you come across an engine with codes 641E or 642E then you've got a Police spec engine.
Posted: Thu Oct 03, 2013 10:07 pm
by PHUQ
You are a very useful person to know Chris, but you do need to get out more :lol:
Posted: Thu Oct 03, 2013 10:13 pm
by 1972TCCOUPE
What was different about the police spec engine Chris?
Posted: Thu Oct 03, 2013 10:37 pm
Let me muddy the waters... :razz:
Looking through the rego data I have for NZ 1800s, I have :-
Engine No. Chassis No. First Reg
18VEH127356 SB28W0169422 23/4/74 (convertible)
18VEH182657 MH45GT81861M 31/5/72
18V247E40668 MH499109807M 7/7/72
18VEH45798 MH4S9S126983M 26/7/72
18VEH48899 MH45912009M 11/7/72
18V247EH9495 MH45927436M 19/4/72
Posted: Thu Oct 03, 2013 11:14 pm
Can't really tell as none of the engine internals seem to be different, however two other items do. A rear mounted oil filter (not sure what that means) and a heavy duty clutch pack.
Posted: Fri Oct 04, 2013 7:06 pm
by Martec
18V F - H13524 was my original TC engine August 1972 (Engine long gone)
